Advice on setup for on/off road
Discussion in 'Suspension' started by iJDub, Apr 3, 2013.
  1. Apr 3, 2013 at 8:58 PM
    iJDub
    iJDub [OP] Well-Known Member
    So I think I'm going to go with Icon coils up front and Icon shocks (no resevoir) in the rear (Stage 1) with All Pro Expo leafs. Light Racing UCAs.
    Is this a good setup for 80% on road / 20% off road driving?
    What other parts should I replace while I'm at it...truck already has 120K on stock suspension.
  2. Apr 6, 2013 at 6:22 PM
    iJDub
    bump
  3. Apr 6, 2013 at 6:24 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    that's a solid setup that'll serve you well. just don't forget the small things like longer brake lines in the rear, new ubolts and you'll be good to go!
  4. Apr 6, 2013 at 8:38 PM
    iJDub
    If I plan on a plate bumper should I get stiffer springs to handle the weight up front?
    What kind of travel should I expect out of the front and rear?
    Anything to do to keep stress off CV joints/boots?
  5. Apr 6, 2013 at 8:41 PM
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
    Not to walk on your post but do you need new branke lines for a 1.5 AAL?
  6. Apr 6, 2013 at 9:28 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    what #rate are the springs you're getting? 2nd gens with plate bumpers usually want 600-650#, depending on the weight up front
    expos are rated at around 11" of travel, so make sure your shocks can handle the travel
    up front, im not exactly sure for 2nd gen MT setups, maybe 9" or so
    and there isnt much you can do to save the boots, they're consumables that will get worn with the lift; the inherent quality of the lift puts the CV's at an angle
    new brakelines are always a good idea when lifting over stock. You don't want the brakeline to be your limit strap
  7. Apr 6, 2013 at 10:21 PM
    iJDub
    Lol. I think someone sells longer CV boots that help keep from tearing due to angle?
  8. Apr 13, 2013 at 9:29 AM
    Dfm155
    Dfm155 Active Member
    2013 Tacoma Double Cab 4x4 TRD Off-Road
    None...yet!
    iJDub, you might want to look into seeing if the ICON rear shocks will work with the Expo's. Reason I bring it up is I wanted the same setup except the standards. The ICON rears are only good for lifts 0-2", and the Expos give you up to 4". Just FYI, I'm trying to figure out which rears to go with, too.
  9. Apr 13, 2013 at 10:34 AM
    iJDub
    I think you're right. I may go with one of the Fox springs listed on All Pro's website then.
