Advice on Shock Absorbers
Discussion in '1st Gen. Tacomas (1995-2004)' started by jjsask, Sep 29, 2010.
  1. Sep 29, 2010 at 9:24 PM
    jjsask
    jjsask [OP] Well-Known Member
    Regina, Saskatchewan, Canada
    2002 XtraCab 4x4 TRD
    I just bought a 2002 XtraCab 4x4 TRD. The truck has the original toyota/bilstien shocks on it and I am fairly sure they are shot. The truck bashes over rough roads with a bone shaker ride and when you rock the truck up and down there is quite a lot of movement.
    The local dealer quoted me $60 each for the rear and $140 each for the front toyota/bilstien shocks. I am looking for a relatively smooth ride but still capable off road and the truck is at stock height and will not be lifted at all.
    Should I go with the OEM shocks for about $400, or can I do better with another option? Also, how difficult is it to replace the front shocks, I know I will need to borrow a spring compressor from somewhere but I would like to know if it is a big job aside from dealing with the springs.
    Thanks,
    John Jesse
  2. Sep 29, 2010 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Check out the Bilstien 5100's. Much better shock than OEM.
  3. Sep 30, 2010 at 8:25 AM
    jjsask
    I took a look at the 5100's it looks like I can get those shocks for $99 each for the rears and $115 each for the fronts. I wonder why the fronts are cheaper than OEM seeing as they have the ride height adjustment and the OEMs don't.
    There is also the heavy duty series available for $88 each for the rears and $75 each for the fronts.
    The pricing does not appear to make any sense between the different options, but oh well. Can somebody comment on specific differences between the three shock options I have listed, as stated earlier I am looking for a rice ride over rough roads but something still somewhat capable off road, I wont be doing anything too intense. Also, does anybody know how hard it is to change the front shocks?
    Thanks,
  4. Sep 30, 2010 at 9:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The dealer is always gonna be much more expensive than aftermarket parts. DownSouth motor sports sells all 4 (front and rear) for about $300.00. Check them out. They are a vendor on here.
  5. Sep 30, 2010 at 9:35 AM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Unless that price includes installation you can do A LOT better. You can get a SET of the Bilstein 5100's for the front from Wheelers Off Road (http://www.wheelersoffroad.com/9504tacoadjbils.htm) or Down South Motorsports (http://downsouthmotorsports.com) for around $175-185. There is a discount code for the down south motorsports purchases. The 5100's are MUCH better than the factory Bilsteins.
  6. Sep 30, 2010 at 10:26 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    5100s are pretty much exactly the same as the HD except they are adjustable. All depends on whether you want to level/lift the front end or not.
  7. Sep 30, 2010 at 12:16 PM
    jjsask
    Thanks for the advice. I will probably get the Bilstein HD shocks as I have no interest in lifting the truck and they are cheaper. The prices I have ($196 for the rear set and $150 for the fronts) are from Essex Distributors who are the Bilstein Reps in Canada. Unless I can get them a LOT cheaper in the USA, the websites one poster gave only had the 5100s, I would rather order them domestically. US brokerage charges are a huge pain. Does anyone know of any local dealers in Saskatchewan?
  8. Sep 30, 2010 at 12:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 4600's are more of an OE replacement shock, while the 5100's are an upgrade. They are valved better for off road, and a little larger in diameter.
  9. Sep 30, 2010 at 3:31 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    5100"s x one million
  10. Sep 30, 2010 at 3:37 PM
    chrisx1
    chrisx1 Well-Known Member
    NE Missouri
    95 4cyl 4x4 5sp
    15x8 Pro Comp Wheels w/4" backspacing, 31x10.50 Mickey Thompson MTZ's, Bilstein 5100's set to 2.5", URD Short Throw Shifter kit, URD rear O2 sensor simulator
    order the 5100's from Downsouth, and have a local tire shop put them on. Total out of pocket should be less than $400
  11. Sep 30, 2010 at 3:58 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    On my '05 the 5100s I added in back were great... under $80 each... in 2007. Only the front 5100's are adjustable.
  12. Sep 30, 2010 at 8:08 PM
    Benji G.
    Benji G. Member
    Benji
    Ruston La.
    03 Tacoma 4x4 2.7L
    2.5" lift
    i'am satisfied with them!!:)
