Advice on some front suspension parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Austin4x4taco, Jul 15, 2021.
  1. Jul 15, 2021 at 4:40 PM
    Austin4x4taco
    Austin4x4taco [OP] Member
    2006 tacoma 4x4 sr5
    I need to replace upper and lower ball joints on my 4x4 tacoma thats at 214,000 miles. I am thinking it is probably a good idea to replace the control arm bushings as well. I have already done sway bar links, hubs, and new bilstein 5100s. I have the 5100s set to max lift and was told by the alignment shop that they couldnt get the camber perfect because of it (expected). Now that I am replacing this, is it economical to just get a stock LCA and switch to a wider UCA? Any recommendations on parts? I am planning on riding this truck till the wheels fall off but I am not trying to spend more money than I have to to have a nice setup that will see some mild 4 wheeling. Also, how do I tell if my cam tabs are flattened/messed up?
    Thanks!
  2. Jul 15, 2021 at 4:41 PM
    Austin4x4taco
    2006 tacoma 4x4 sr5
    Before the 5100s I ran a crappy spacer lift that was at the same height, if that makes any difference
  3. Jul 15, 2021 at 5:10 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    What does that have to do with the price of tea in China???? Lmao
  4. Jul 15, 2021 at 5:24 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Replacing lower control arm bushings…
    Easier to go to college, become a brain surgeon, then pay someone else to do it.
    Because - it - fucking- sucks.
    That being said I jacked my truck up and you could easily see that the alignment tabs would move with the lower LCA, if this is the case prepare for more suck.
    Also just look at your tabs, you’ll see if they are flattened/bent
  5. Jul 15, 2021 at 6:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Even more suck if the Cams are frozen stuck.
    And don’t count on the alignment shop telling you they are stuck.
    They don’t want to do them any more than you do, let lone weld new tabs.
    :sawzall: :welder:
  6. Jul 15, 2021 at 7:31 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Replace the uppers with JBA ucas and replace the lowers with OE.
  7. Jul 15, 2021 at 9:18 PM
    Austin4x4taco
    2006 tacoma 4x4 sr5
  8. Jul 16, 2021 at 7:16 AM
    gotoman1969
    I’m a firm believer. You get what you pay for. I have JBA zero isssues
  9. Jul 16, 2021 at 9:38 PM
    TacoTuesday1
    SD CA
    weak aluminum for suspension that typically comes on performance cars for light weight seeing mild street use, designed to bend easily
    the same metal made by recycling and melting down an empty Pepsi can
    put on a 4x4 off road truck that came with steel, in an aftermarket scene where 99% of offerings are also steel but welded
    interesting concept
  10. Jul 17, 2021 at 7:48 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Yeah so.. Icon makes a billet UCA that is a very solid piece, that said its about 4 times as much as the RC ones. Not all aluminum is created equal.. Or you can choose to think of all the crushed up pepsi cans the next time you fly in an airplane anywhere..
