Advice on suspension upgrades??
Discussion in 'Suspension' started by Lordofire77, Mar 21, 2014.
  1. Mar 21, 2014 at 8:43 PM
    Lordofire77
    Lordofire77 [OP] New Member
    Sam
    North Dakota
    05 access cab TRD hungry for upgrades
    I have a 05 access cab, it has the oem leveling kit and slightly oversized tires, other than that it's stock. It's my daily driver so I don't want to go too crazy with a lift but I drive washboard/rough gravel roads to and from work every day. Any suggestions on smoothing out the ride, with out taking the ability to run down the hwy at 75-80 mph.I tend to be a pretty aggressive driver, so idling down the road at 25 isn't exactly what I have In mind. Right now I am just trying to gather information so anything helps.
    THANKS
  2. Mar 21, 2014 at 8:50 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    What is the oem leveling kit? Was it a dealer add on?
    To upgrade and give a little more lift all around I'd suggest some OME springs along with Dakar leaf springs.
  3. Mar 22, 2014 at 5:02 AM
    Lordofire77
    Sam
    North Dakota
    I bought the truck used, the dealer I got it from said it was a oem option that had been put on, basically a 1-1 1/4 inch spacer block on top of the strut.
  4. Mar 28, 2014 at 12:15 PM
    802hwl
    802hwl Member
    Vermont
    2010 4x4 tacoma sr5 5speed 4-cyl
    I consider myself in the same position position as you, lordofire77. would a 2.5" leveling kit in the front along with an add-a-leaf be appropriate? I am looking to get a tad more height without looking too aggressive, maintain a smooth ride at high speeds while adding some stiffness for mud season and logging roads.
