Advice on switch type
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jgunccrugby, Dec 31, 2012.
  1. Dec 31, 2012 at 4:56 PM
    jgunccrugby
    jgunccrugby [OP] Well-Known Member
    Mount Holly, NC
    13 PreRunner SR5 DBL Cab
    Tacoma Seat Covers, Tacoma Kick Guards, Nerf Bars, Front window tint. To come: Bull Bar
    Tell me what your thoughts are on this.
    I'm thinking of running a constant hot or figuring out how to do a standard on/off auxiliary power source witha toggle switch override.
    Ideally I would have Auto/constant hot/off. Or a switch from contestant hot to igniitian activated. Any thoughts on how to do this? I have been looki g at diagrams, switches, and everything in between.
    I was also thinking of using the same application, ideally, for auxiliary back-up lights so that they activate with the normal reverse but also can have an override option if the truck is off or in park.
    Any thoughts?
  2. Dec 31, 2012 at 5:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What?:confused:
  3. Dec 31, 2012 at 7:22 PM
    jgunccrugby
    Mount Holly, NC
    Ok, let me try to reword this:
    Aux plug with power all the time and use a switch to return the outlet to only being active when the vehicle is on.
    On the backup lights: primarily have them linked in with the lightes thack kick on when the vehicle is in reverse but have an override so they can be on without the truck being on or in reverse
    Help?
  4. Dec 31, 2012 at 7:39 PM
    Series1000
    Series1000 Gots a Taco!
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    3" Redi-lift (spacer lift) up front
    Honestly, it may be more complex than your thinking. Any good repair shop can do it for you, it will be alot of work to do it the way you want.
  5. Dec 31, 2012 at 8:13 PM
    jgunccrugby
    Mount Holly, NC
    That is good to know. I didn't think it would be terribly difficult... I can figure out about anything as long as I have a diagram and know the parts. It doesn't appear that this has been attempted though. May take a different approach on each.
    Charging line with direct power and a switch then just tap into the back up lights for the other.
  6. Dec 31, 2012 at 8:16 PM
    jgunccrugby
    Mount Holly, NC
    You sir are awesome....
  7. Jan 1, 2013 at 1:37 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Just use diodes dude. Way simpler then an on off on switch.
    Wire the rear lights strait to the revers lights. Then have a diode on the power for the lights right before it connects to the lights. Then set up a switch like you normally would for the lights. But put a diode on the power wire. Simple as that.
    I'm still slightly confused on what you want for the first part...
  8. Jan 2, 2013 at 7:30 PM
    jgunccrugby
    Mount Holly, NC
    Would it be advisable to add a fuse box under the hood?
  9. Jan 2, 2013 at 7:30 PM
    jgunccrugby
    Mount Holly, NC
    And thank you all for the help.
  10. Jan 2, 2013 at 7:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If you plain adding lights..or other such things..yes get a fun box. Well worth the money
  11. Jan 2, 2013 at 7:51 PM
    jgunccrugby
    Mount Holly, NC
    Ok. Thanks.
  12. Jan 4, 2013 at 9:58 AM
    jgunccrugby
    Mount Holly, NC
    Last question, until I actually start working on this thing this weekend.
    If I add a fuse box and run these items off of the fuse box is my thinking right that: Each existing reverse bulb draws 1.6a and each 55w draws 4.6a so:
    (1.6a*2)+(4.6a*2) = 12.32 Amps i.e. fuse needs to be 15 amps?
