Advice on these two lift kits.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueHeli, Feb 18, 2016.
  1. Feb 18, 2016 at 10:02 PM
    BlueHeli
    BlueHeli [OP] Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
    So I have had my 2013 dcsb 4x4 for over 2 months now. Have been researching lifts since I bought it. There seems to be no simple way to lift a Tacoma. I have narrowed down and what I am looking for is between the two following kits.
    A heavy duty OME kit with 886 coils, 90000 firm shocks, LR UCA's, and a new Dakar leaf pack. $1684.99 w/free shipping not including labor.
    http://www.headstrongoffroad.com/st..._Emu_Kit_w/_Dakar_Leaf_Pack_-_05__Tacoma.html
    I would like this one because I do plan on installing a plate bumper and a winch plus other options like a bed rack or shell. And I still want it to be a truck so I can haul house hold items. I would like to run 33" tires but would settle on 32"s if needed.
    The other option I am thinking about going with is an Icon stage 4 kit with tubular control arms. $3000ish depending on where I buy it from.
    http://iconvehicledynamics.com/shop...5-suspension-system-stage4-w-tubular-uca.html
    Money isn't an issue for the lift. But I have zero need for a long travel suspension. All I really plan on is running trails, camping, fishing, hunting, towing and maybe traveling in some canyons in Northern AZ from time to time. Which lift is going to be more beneficial for these tasks? I would rather do it once and be done with it. I don't really want to get a lift only to spend another 2000 bucks upgrading it again. To me that is money better spent elsewhere.
    Any input on this would be greatly appreciated and very helpful.
    :burnrubber:
  2. Feb 19, 2016 at 5:15 AM
    Simple Man
    Simple Man Well-Known Member
    Puget Sound
    2014 Cement FJ Cruiser
    IronMan Foamcell Pro suspension. JBA UCAs SCS Stealth 6 Wheels with Nitto Ridge Grappler LT255/80R17
    My need for suspension is pretty much the same as yours (bumper/winch/canopy/trail use/hauling camping supplies/towing utility trailer/no long travel) and I just ordered the OME kit you are looking at from Headstrong two days ago. I did a ton of reading before ordering and feel confident the OME will give me what I want for this application. OME is well respected for their quaility products. While King makes an excellent product, and would work for what you are doing, it is desigened for a harsher use application that it does not look like you need. Good luck with your decision.
  3. Feb 19, 2016 at 6:30 AM
    BlueHeli
    AZ
    None
    Awesome thanks for that info. what size tires are you going with on the OME kit?
  4. Feb 19, 2016 at 6:33 AM
    DrFunker
    DrFunker is Funkified!
    Didums
  5. Feb 19, 2016 at 6:34 AM
    BlueHeli
    AZ
    None
  6. Feb 19, 2016 at 6:40 AM
    DrFunker
    Didums
    Geekhouse has good lift advice.
    BlueHeli [OP] and geekhouse23 like this.
  7. Feb 19, 2016 at 6:43 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    I'm running all of that except the UCA's and dakars, with ARB and winch(add 250 pounds to the front end)...and im clearing 285's no problem with wheels at 4.5" BS, i will probably go to 295 for my next tire
  8. Feb 19, 2016 at 6:46 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Hi :wave:
    OP,
    1) How soon/long is the plan for bumper and winch? Ride will be harsh til you get those items with 886 coils.
    2) I HIGHLY recommend adding the D29XL to the Dakar pack and run 6+2 for the added weight of a shell/rack.
    Don't forget new brake lines (especially in the rear) and new bump stops (preferably all around)
    How much do you want to trim? Running the full OME kit you mentioned (minus 886's for now) and 285/75/16's and I had to remove the mudflaps, trim plastic where they mount, cab mount chop and beat the pinch weld in with a BFH
    DrFunker likes this.
  9. Feb 19, 2016 at 6:47 AM
    g8erh8er
    g8erh8er Well-Known Member
    Land O Lakes, Fl
    2012 Tacoma DC 4x4 Sport
    Icon all day any day. I have the 2.5 non reservoirs front, UCAs, 2.0 non resi rears, and OME Dakar springs. Around 3 inches of lift running 32" Duratracs. Couldn't be happier with the ride.
    I don't off-road at all except for a camping trip once a year. This is my daily driver and it now rides better than it did stock in my opinion.
  10. Feb 19, 2016 at 6:48 AM
    DrFunker
    Didums
  11. Feb 19, 2016 at 6:48 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Toyo M55 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 27F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, Cobra 75WXST cb with rear mounted Wilson 3' antenna on Shmellmopwho mount, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, 5100s with 885 coils and 1/4" spacers, SPC LR UCAs, 2wd low range mod
    Look into 255 size tires. You won't get that wide stance, but you'll do less trimming - and they're true 33s.
    Edit: 255 is the width, 255/85/16 and 255/80/17 are 33s.
    geekhouse23 likes this.
  12. Feb 19, 2016 at 6:49 AM
    DrFunker
    Didums
  13. Feb 19, 2016 at 6:50 AM
    geekhouse23
    New TW name? :notsure:
  14. Feb 19, 2016 at 6:53 AM
    DrFunker
    Didums
    :laugh:
    You da man with the lift knows, no? :rasta:
  15. Feb 19, 2016 at 6:53 AM
    geekhouse23
    Edited my title on the left <-
  16. Feb 19, 2016 at 6:54 AM
    neverstuck
    neverstuck Well-Known Member
    Vancouver Island
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    If you are running OME shocks you do not need extended brake lines. The shocks will limit out before you overextend the lines. I bought extended lines and didn't bother installing them with my lift. They're still in my tool box.
    If your truck will be empty most of the time I don't think you need the extra leaf with the Dakars. Even with the canopy/camper shell. I think you'd be taking on a harsher ride unnecessarily. The standard Dakar pack can handle loads of weight. Just my .02
  17. Feb 19, 2016 at 6:55 AM
    DrFunker
    Didums
    :cheers:
    :rasta:
    :proposetoast:
    :sandwich:
    :pray:
  18. Feb 19, 2016 at 6:57 AM
    geekhouse23
    True. Not sure if the OP is going with a rear bumper though. Assumed eventually since he's running one up front.
    Glad I, personally, did them when it was all apart. Going to make this shackle flip and 12" shock swap coming up (month or so) easier.
  19. Feb 19, 2016 at 8:56 AM
    mattraptor
    mattraptor Well-Known Member
    Fort St John BC
    2009 ACLB TRD Off Road
    265/70R17 Duratracs, fog lights anytime
    If money isn't a big deal I agree....Install airbags for the extra load cap when you need it
  20. Feb 19, 2016 at 9:21 AM
    neverstuck
    Vancouver Island
    13 DCLB sport
    This is about 1000 lbs loaded on standard Dakars and they settled maybe an inch. I don't have airbags but I do have Timbren bumpstops.
    BlueHeli [OP] likes this.
