Advice on tire/wheel sizes please.
Discussion in 'Wheels & Tires' started by BrandonG, Jan 8, 2011.
  1. Jan 8, 2011 at 9:51 PM
    BrandonG
    BrandonG [OP] Active Member
    Brandon
    Tennessee
    Hey guys, I in the process of getting new rims/tires since the tires that came on my truck are starting to get slick. Could I fit 265/70/17s on 17x8 rims and get them under my 2010 Tacoma Sport WITHOUT any lift? I don't mind cutting a little if necessary. Don't get me wrong, I'm not asking for a handout, I've spent a good while trying to figure this out myself with the other posts/stickies...but I can't seem to grasp the sizes and understand exactly what I can and can't fit. Someone please enlighten me.
    Thanks in advance,
    Brandon
  2. Jan 9, 2011 at 5:17 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Those will fit no problem. May have to trim or remove front mud flaps, but other than that you're good.
  3. Jan 9, 2011 at 8:08 AM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    Remove the front mudflaps, and you're golden.
  4. Jan 9, 2011 at 5:30 PM
    BrandonG
    Brandon
    Tennessee
    Thanks for the advice guys. After some more research...I think I may actually step up to a 17x9 wheel. I want a little more agressive look, but I really don't want to get the 285 tires for gas mileage, etc. Will 265/70/17s fit on a 17x9 wheel?
  5. Jan 9, 2011 at 7:03 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Yes they will work but your rim will most likely be wider than the tread on your tires. Making it look kinda stretched.
  6. Jan 10, 2011 at 5:56 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I have 265's on a 9" rim and they aren't stretched at all. 265's are 10.5" wide.
  7. Jan 10, 2011 at 6:22 AM
    TacoSupreem
    Hayden
    Kentucky
    I personally don't like the bead of the tire to be wider than the contact patch or tread width. A 265 will have around a 8-8.5" tread width.
  8. Jan 10, 2011 at 6:32 AM
    TacoSupreem
    Hayden
    Kentucky
    I have 16x8's with 265's and they look ok. I miss the 285's, but oh well I think I'll go back to the wider tires next time.
