Advice on towing a 6 by 12 U-Haul trailer
Discussion in 'Towing' started by abench46, Mar 20, 2024.
  1. Mar 20, 2024 at 4:16 PM
    abench46
    abench46 [OP] New Member
    2019 Tacoma Trd, pro
    6 inch lift
    I am planning on moving from California to Indiana roughly about 2300 miles I have a 2019 Tacoma Trd pro with tow package and a 6 inch lift. I have never towed anything wondering if I can tow it safety? Any advice would be helpful?
  2. Mar 20, 2024 at 4:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    Depends on loaded weight, tongue weight, your hitch, if trailer has brakes, terrain travelled and weather condition along the way.
    Look at weight sicker in your door jamb. Subtract tongue weight and the remainder is what's left you can carry in truck, including bodies
    Most folks get scary low MPG
    Don't be in a hurry.
    Being a Pro doesn't factor in here that I'm aware of.
  3. Mar 20, 2024 at 4:29 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Don't forget to leave it in 4th. to tow with.
  4. Mar 20, 2024 at 5:44 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Would be best to stick to 60-65 while towing the brick.
    Where are you headed to in Indiana? I settled down here in north central Indiana after years in the military. Didn’t want to, couldn’t stomach the idea of going back to Illinois.
  5. Mar 20, 2024 at 8:15 PM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    Look for the flattest route, like from LA heading East. It is worth a few miles to avoid mountains.
    Tiedie likes this.
  6. Mar 21, 2024 at 8:28 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    OP- you have a 6” lift, are you regeared and tuned? If not, you’ll likely see avg MPG of 9-12 while towing on flat.
    Do you have upgraded rear leafs(AAL/bags/whole leaf swap)? I’m only asking bc the factory tacoma leafs are super weak, and don’t handle a load well at all.
    Choose your route wisely(avoid Mtn passes if possible) and keep it under 65, watch trans temps too(can rise rapidly while towing)
    Tiedie likes this.
  7. Mar 21, 2024 at 8:33 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Also you may want a signifcant drop hitch. I am not lifted much but have a very HC bumper and hitch setup. This is an 8" drop. Hitch receiver height is around 28" on my bumper.
    AP1GczNw0R55uKUoC_72G-dnuiSrxb8lox8_AOAu_ea72052b13a63d562d6ee450b225d9e36bf138ff.jpg
    ScrippsRanch67 and Tiedie like this.
  8. Mar 21, 2024 at 4:36 PM
    Tiedie
    David
    WFOY
    I run a 6" drop all the time, lifted 3" all the way around.
  9. May 2, 2024 at 11:12 AM
    TacoTuesday1
    FL
    drive safe. That’s all it was to me.
    question is why burn $2k on a parachute uhaul that surge brakes every shift
    versus buying a brand new trailer for $1k, no time limit, sell it when done
    That weighs much less
    6x12 is 2000lb unloaded
    mods made my regular adapter too high. Had to switch to an adjustable drop that goes lower. Uhaul website recommends 18” height in the ball area.
    MGMDesertTaco and Travlr like this.
  10. May 2, 2024 at 11:33 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    My two cents: if all your stuff won't fit in a UHaul 5x9 trailer (one size smaller, much, much easier to tow), then I'd rent a 10' box truck + car hauler and tow the Taco.
    How did we land on $2000 for the trailer rental? That seems pretty high, a truck should cost about that much, but not the trailer.
    If that's the real price, I'd be looking at PODS or something similar; same money, less headache.
    If you've never towed, I wouldn't recommend the 6x12 for the Taco for that distance.
    Maybe get a friend to help you with the trip as well, would be way more enjoyable. Not impossible, but mind-numbing driving under 65 mph for all those miles.
    lowmower, MGMDesertTaco and tacoma_ca like this.
  11. May 2, 2024 at 11:41 AM
    545 Well-Known Member
    2015 Access Cab
    You aren’t getting an enclosed trailer that will make it across country for $1000 anymore
    But it’s what I did years ago
  12. May 2, 2024 at 11:46 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    Since I'm procrastinating from work, here are the UHaul rates from LA to Indianapolis:
    10' truck + car hauler: $2800
    6x12 trailer: $1700
    5x8 trailer: $900
    So yeah, forget the box truck, since you still have to drive that POS, and get a POD or something if you can't fit in the 5x8 + light things in the truck bed.
    Any way, the 6" lift plus (I assume) larger tires are going to make any towing suck more than usual.
    Edit: I doubt OP is keeping up with this anyway.
  13. May 2, 2024 at 11:51 AM
    TacoTuesday1
    FL
    Did 14 hours through CO mountains with a 6x12.
    It used to be as low as $400. Not anymore.
    Around $2k+ now.
    and that’s without the rickety inefficient mileage charge of a box truck.
    even if a smaller Uhaul is cheaper
    5x8 around $1k maybe more
    Depending on states and distance
    why not buy brand new for the same price then sell it when done
    No time limit
  14. May 2, 2024 at 11:52 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Not sure where you're finding an enclosed trailer for $1k. https://www.mirsbergersalesandservi...ies-6x10-cargo-enclosed-trailer-hJpq|Kne.html
    A buddy just moved from here to AZ. He rented a truck and pulled his truck on a trailer. Don't know what that cost him, but it kept a bunch of wear and tear off his truck.
    lowmower likes this.
  15. May 2, 2024 at 11:55 AM
    TacoTuesday1
    FL
    don’t know what you mean by wear and tear. Towed a trailer moving 3 times. Didn’t notice anything.
    no not enclosed.
    Utility trailer.
    rumor has it utility trailer can hold at least two layers of boxes if they’re strapped down. Which may be enough. And be lower acting less like a parachute. They also weigh less.
    Higher stacking may be possible by putting plywood walls or welding higher framework. Don’t know how much that modification would cost or lead time.
  16. May 2, 2024 at 12:02 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Open trailer isn't secure at night. Open trailer doesn't like rain. It's not very likely you can make it across the plains this time of year without hitting rain.
    Also depends what you intend to put in the trailer. OP's title says 6x12, so I'm guessing enclosed and probably a fair amount of household goods.
  17. May 2, 2024 at 12:04 PM
    TacoTuesday1
    FL
    zero furniture
    mostly mechanic tools and truck stuff
    Plan is heavy duty totes. Lid closed should keep water out.
    Wood decking on the trailer I think will handle just a week of weather.
    It looks stronger than the mesh floor trailer variant that costs the same price.
    enclosed with a lock in a hotel where you can’t hear it? Bolt cutters. Steal the trailer.
    sure open deck is open. With ratchet straps. Potential motion sensing alarms hidden inside the totes.
    parked in the middle of nowhere with a guy sleeping 5 feet away. Sounds like a harder target to me.
    with a bunch of ratchet straps securing down and mesh netting they’ve got their work cut out for them.
    add a tarp
    it worked for Borat. The terrain looks the same if not harder.
  18. May 2, 2024 at 12:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It's all about how much weight you're pulling. If your truck were stock, I'd say 4500-5000 lbs in the trailer, but nothing in the truck other the driver and one passenger. Your truck HAD about 1000-1200 lbs of payload when it left the factory. That means you can either put about 1000 lbs in the truck (including driver and passengers) or pull about 4500 lbs. But you have to pick one, you can't do both.
    BUT... your truck has been heavily modified. I'm sure your payload is reduced by the weight of everything you've added. With a 6" lift I doubt you're running stock tires. With 33" tires you should be OK but you will feel less power when towing. If you have 35" tires on the factory gear ratio your truck will really struggle with a load.
    Especially crossing the Rockies. I don't know what your route will be, but if you have to climb any 10,000' passes with 35" tires and a loaded trailer you're going to REALLY struggle. Most engines lose 3% of their power for every 1000' elevation gain over sea level. At 10,000' your engine is only putting out about 70% of the power it does at sea level. At even 5000' you start to feel power loss.
  19. May 2, 2024 at 12:41 PM
    TacoTuesday1
    FL
    then rev it and slow down. Flashers on right lane. Just like what semis do for the same reason all the time. That’s what I did.
    if it’s big tires should probably be regeared already in which case that may not apply.
  20. May 2, 2024 at 12:41 PM
    MGMDesertTaco
    Old post, but Uhaul always charges more to leave CA than to return there.
    I second the POD storage or box truck and trailer. POD would be so much easier. Fly out imo.
