Advice on towing
Discussion in 'Towing' started by Nadalee7, Aug 5, 2009.
  1. Aug 5, 2009 at 12:27 PM
    Nadalee7
    Nadalee7 [OP] New Member
    Missouri
    4x4
    I have a 03 Tacoma 4x4 V6 extended cab with tow package. What is the largest "dry weight" on travel trailer I should be looking at? Without adding anything to the truck.
    Is a 3980lb UVW 23.5 ft Forest River Surveyor too big?
  2. Aug 5, 2009 at 12:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! To get an accurate answer, your going to have to know the exact weight of the tralor "Wey" with all cargo you will be carrying.
  3. Aug 5, 2009 at 1:37 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What's the tow rating for the 03 tacoma w/ tow package?
    I think it's only 5,000lbs.
    Get the trailer weighed....and don't exceed 5,000lbs.
  4. Aug 5, 2009 at 1:46 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    A trailer that big may control the truck more than truck controls the trailer, especially at freeway speed. As you go around a corner, the truck may start to sway. This is very dangerous. I would suggest a smaller, lighter trailer or a bigger truck. I used to have a 1998 Jeep Cheokee with a 4.0 six cylinder. It had plenty of power to tow with, but if I wasn't very careful with my speed around corners, it was scary how much it moved around. I replaced that Jeep with a 1995 Chevy K1500 to tow with and never had an issue. A second gen Tacoma would probably tow much better. JMO.
  5. Aug 5, 2009 at 2:58 PM
    gus54
    gus54 Well-Known Member
    Gus
    Cleveland, Ohio
    2016 Quicksand Tacoma TRD Off Road
    Undercover Lid, BFG KO2 AT
    Our new '09 SR5 with tow package is supposed to be rated at 6500#. We looked at some Travel Trailers and it was recommended to stay at least 1K below that rating with the dry trailer weight. I would guess it would be the same for you - stay at least 1K beneath to allow for stuff. But they also said they figure in wind resistance and it seems that a 26' -28' weighing about 5K or a little more would be about max.
  6. Aug 5, 2009 at 3:11 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Welcome to TW!
  7. Aug 6, 2009 at 5:31 AM
    Nadalee7
    Missouri
    4x4
    Thanks for all the responses. I appreciate it. Can someone give me a dry weight number to be looking at? example: 3000 lbs etc.
  8. Aug 7, 2009 at 5:11 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    You are not looking at dry weight. You need to be looking at GVWR. Which you will find on a sticker inside on of the kitchen cabinet doors in the rigs you are looking at. Dry weights in brochures do not tak into account any installed options, water, propane, and any of your camping gear, and you would be surprised how quickly all of that adds up.
    example: Dry weight on my trailer is 3125. Wet and loaded it's 3750, but that is just with food, cloths and gear for me, the wife and one dog. It will jump exponentially if you have kids with all the crap that they require.
    If you want an arbitrary number then no more than 3500lbs max dry weight, but I urge you to actually read the weight stickers of the units you are looking at.
  9. Aug 7, 2009 at 4:50 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Find a trailer with a GVW of 5000# or less. That way when it's loaded, you know you're safe. Best to keep the trailer not maxed out, as the load in your truck and trailer together must be within your GCWR (gross combined weight rating). My experience is that most trucks are capable of 100% of their rating, but it will be working it.
  10. Aug 20, 2009 at 5:45 AM
    Nadalee7
    Missouri
    4x4
  11. Aug 20, 2009 at 6:32 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Looks good! Anymore pics of it? How does your taco pulling it?
