Advice on water pump
Discussion in 'Off-Topic Discussion' started by NMTrailRider, May 14, 2015.
  1. May 14, 2015 at 6:25 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    hey guys... My grandparents have a little cabin for summer use and I winterize it ifor them in the fall and open it up in the spring. I remove a 1/2" bolt (drain hole) to drain the water pump in the fall and remove another bolt on top to prime it in the spring. It can be REALLY difficult to get the bolts out. What would you recommend I use to lube a bolt that only gets removed once a year?
  2. May 14, 2015 at 6:38 PM
    GSHEP4
    GSHEP4 Well-Known Member
    Lehighton, PA
    2014 spruce mica sport
    s/c,fluid film, bug shield, window vents, under hood lights, bed lights, tailgate reinforcement, and more.
    You could try Teflon Tape.
    NMTrailRider[OP] likes this.
  3. May 18, 2015 at 10:26 AM
    D50boy
    D50boy Well-Known Member
    Kenneth
    Texas
    They sell food grade anti seize compound for bolts. Just do a search for nontoxic anti seize in Google.
  4. May 18, 2015 at 10:29 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  5. May 18, 2015 at 3:59 PM
    NMTrailRider
    New Mexico
    Thanks very much, guys!
    D50boy likes this.
