ADVICE: PLEASE AND THANK YOU
Discussion in 'Suspension' started by joxam, Apr 21, 2018.
  1. Apr 21, 2018 at 8:54 PM
    joxam
    joxam [OP] Member
    2014 TACOMA BRM TRD OFFROAD
    FRONT: BILLSTEIN 5100 WITH 3" TOYTEC COILS REAR: BILLSTEIN 5100 WITH 2" SKYJACKER RTC515 SOFTRIDE AAL BODY ARMOR ROCK STEPS 265/75/16 All Terrain T/A KO2 All BFGoodrich RAD INDUSTRIES GRILL W/COLOR MATCH SURROUND
    2014 Off road RBM DC short Bed. So...about to put in a 3"toltec/billstein 5100 in fronts and a 3" skyjacker AAL in the rear w/billsteins- No diff drop, stock UCA's, and a 1/4" taco lean spacer+Body Armor Rock Steps,on 265/75/16 BFG Ko2's . Any suggestions of anything I am missing before I install?
  2. Apr 21, 2018 at 9:01 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Welcome
    :hattip:
    If you're going 3" up front you'll probably want some aftermarket UCA's to get proper geometry up front.
  3. Apr 21, 2018 at 9:04 PM
    joxam
    joxam [OP] Member
    From what I've heard it will only go up 2.5 with lift for double cab which is maxed out or could be close? Should I go and try alignment or just pony up for the new UCA's?
  4. Apr 21, 2018 at 9:05 PM
    joxam
    joxam [OP] Member
    I hear the light racing UCA is the way to go or should I look at others? Recommendations please and thank you!
  5. Apr 21, 2018 at 9:09 PM
    hoverlover
    Mostly Zip-Ties
    I have no experience with the light racing UCA's but a lot of people like them. I've used Camburg UCA's with Moog ball joints and I currently have Total Chaos UCA's. The TC arms are great. Alignment is easy and the truck tracks like a laser beam. Very happy with them. I had no issues with the Camburgs but the TC arms just feel a lot better.
    joxam[OP] likes this.
  6. Apr 21, 2018 at 9:15 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Why no diff drip?
  7. Apr 21, 2018 at 9:17 PM
    hoverlover
    Mostly Zip-Ties
    The TC arms do use a uniball.
    I've learned the hard way to do it right the first time. I could have saved a lot of time and money just spending a little more initially to get exactly what I wanted for my truck.
    Do it right, do it once. Buy once, cry once.
    Just decide what you want to achieve and do your homework on the available products to meet your goal. Don't rush into anything.
    Edit: corrected spelling
    joxam[QUOTED][OP] likes this.
  8. Apr 21, 2018 at 9:18 PM
    joxam
    joxam [OP] Member
    I've heard that in 2nd gen it its pointless because it just rotates and is so minuscule that it is a waste of time/money. Also read that it can cause more damage when off-roading than just replacing the cv boot.
    hoverlover likes this.
  9. Apr 21, 2018 at 9:21 PM
    hoverlover
    Mostly Zip-Ties
    TW is a wealth of information for our trucks. And all kinds of people doing all kinds of things. It's not too difficult to find what does and doesn't work with our trucks on this website. Just do a little reading and you'll find everything you need. Good luck with your build. Post up some pics, too. Everyone loves pictures.
    Biscuits likes this.
  10. Apr 21, 2018 at 9:22 PM
    joxam
    joxam [OP] Member
    Thanks hoverlover! I am of the same school of thought on doing it right the first time
  11. Apr 21, 2018 at 11:20 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    If you want that much lift you are def going to need new UCAs for a proper alignment.
  12. Apr 22, 2018 at 12:34 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Echoing what's already been said, prevent the headaches and alignment issues by buying quality UCAs.
    I've run Dirt King UCAs for years and never an issue. Bulletproof and the customer service is top notch.
    https://dirtkingfabrication.com/col...products/bushing-upper-control-arms-dk-811902
  13. Apr 22, 2018 at 12:23 PM
    joxam
    joxam [OP] Member
    After more research and looking at my bank account I have decided to get the SPC UCA's as well as a carrier bearing drop kit ($450 on Amazon). Still not sold on the front diff drop.
  14. Apr 22, 2018 at 1:57 PM
    Biscuits
    I don't know of anyone personally that uses a front diff drop.
