Advice Please
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rocket86, Aug 30, 2025.
  1. Aug 30, 2025 at 1:48 PM
    Rocket86
    Rocket86 [OP] Well-Known Member
    2002 TRD 4x4 EXT CAB AT 3.4 195,000. Most OME PARTS.
    Changed All Fluids. Rear was BLACK! Replaced ujoints & rear carrier support. Rear moan (RLocker off) in drive and neutral, ESPECIALLY WHEN COASTING and foot off the gas. NO Leaks.Mech says pinion bearing?
    Rear on stands, listening w long Flat scrwdrvr. In Dr I can stop pass tire but Dr side won’t stop. Dr side is making a low dull whup whup whup whup. PLEASE tell me how to diagnosis this sound. It’s starting to get bad. Wheels have no play.
  2. Aug 30, 2025 at 3:24 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Is the whup whup sound rotational?
  3. Aug 30, 2025 at 3:31 PM
    Darce
    Darce Well-Known Member
    2003 Tacoma
    The fluid could be black because its just never been changed, I'd say this is unfortunately typical. You just don't want any metal in it. Do you hear the whup noise from the wheel area or the center of the diff area?
    ControlCar likes this.
  4. Aug 30, 2025 at 3:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A howl while coasting is certainly a sign of a bad pinion bearing.
    The whup, whup, could be a number of things. Depends on where you hear the noise the loudest?
  5. Aug 30, 2025 at 4:08 PM
    Rocket86
    I drained it and filled it with the best
    In all due respect is there another way to hear a sound unless the wheel is spinning? If you mean counter clockwise while in drive then yes.
  6. Aug 30, 2025 at 4:11 PM
    Rocket86
    While in drive up on jackstands and giving a little gas. The driver’s side rear makes a dull low whup whup consistent low sound.
  7. Aug 30, 2025 at 4:13 PM
    TnShooter
    Deogee
    STOCK
    Where at?
    On the axle tube?
    Closer to the wheel or the center differential?
  8. Aug 30, 2025 at 4:14 PM
    Rocket86
    Great question, do you know of the best way to make a homemade stethoscope?
  9. Aug 30, 2025 at 4:21 PM
    Rocket86
    I changed the differential oil with the best money could buy with spec about 8,000 mls ago.
  10. Aug 30, 2025 at 4:22 PM
    Rocket86
    About 8,000 miles ago I drained all that black oil and replaced with the best money could buy according to spec.
  11. Aug 30, 2025 at 4:23 PM
    TnShooter
    Deogee
    STOCK
    The long flat screw driver like you were using is about as good as home-made as it gets....
    Wooded broom handles work too. For hard to reach places.
    Rocket86[QUOTED][OP] likes this.
  12. Aug 30, 2025 at 4:24 PM
    Rocket86
    The vibration is coming through the floor board and steering wheel.
  13. Aug 30, 2025 at 4:27 PM
    Rocket86
    When up on jack stands
  14. Aug 30, 2025 at 4:27 PM
    Rocket86
    I replaced it with the best money could buy per spec
  15. Aug 30, 2025 at 4:30 PM
    TnShooter
    Deogee
    STOCK
    Pretty sure Spicer was the OEM supplier for u-joints and carrier.
    But I don NOT think that either of those are your issue.
  16. Aug 30, 2025 at 4:31 PM
    Rocket86
    No sir, I replaced them with Koyo or high end Spicers.
    TnShooter[QUOTED] likes this.
  17. Aug 30, 2025 at 4:34 PM
    Rocket86
    Now guys listening to the rear remember with a long flathead screwdriver. The front of the third member sounded a little grinding, certainly wasn’t smooth.
  18. Aug 30, 2025 at 4:40 PM
    TnShooter
    Deogee
    STOCK
    That's where the pinion bearing is at....
    Do you have any play in the flange where the driveshaft bolts to the rear diff?
    Grab it and push up/ pull down on it.
  19. Aug 30, 2025 at 4:50 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
  20. Aug 31, 2025 at 7:57 PM
    Rocket86
