Advice regarding lift for Tacoma 2012
Discussion in 'Suspension' started by Madox777, Aug 8, 2015.
  1. Aug 8, 2015 at 10:56 PM
    Madox777
    Madox777 [OP] Member
    Madox
    2012 Tacoma TRD Sport 4wd
    RAM 1500 2014
    Hello, guys, I need your advice regarding the lift for my Tacoma 2012 longbed. A year ago I installed full Ironman 2 inch lift with all shocks and springs. Now it looks few shocks are bad and should be changed. I would like to install 3" Ready lift spacers and 1" block to the back. My first question - is it possible to install Readylift spacers on top of Ironman shocks? And second option - if I change shocks what kind of shocks I can install along with readylift spacers? Thanks
  2. Aug 8, 2015 at 11:00 PM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Madox777[OP] likes this.
  3. Aug 8, 2015 at 11:09 PM
    Madox777
    Madox
    RAM 1500 2014
    Thanks for your advice. Do you think OME is far better than Ironman? I heard about of more or less same quality of both. Anyway I would like a bit more lift. But will consider to replace for OME shocks. Thanks
  4. Aug 8, 2015 at 11:11 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    OME all the way, the fact that your shocks went out after a year from that ironman lift should say plenty if you ask me
  5. Aug 8, 2015 at 11:16 PM
    300AACTaco
    Alaska
    OME is raved about on here, can't go wrong with them, they handle harsh Alaska roads where I live no problem, and do great off road. So i'm sure you'll love them if you get a set. Plus you won't have to replace them after a year.
  6. Aug 8, 2015 at 11:22 PM
    Madox777
    Madox
    RAM 1500 2014
    What if I replace all shocks for OME and leave the springs of Ironman front and rear?
  7. Aug 8, 2015 at 11:26 PM
    300AACTaco
    Alaska
    I wouldn't, Ideally you want the OME shocks with the OME coils (springs, same thing), and then ditch the blocks in the rear and go with an AAL. You can have top plate spacers up front that aren't nearly as bad as a ready lift or something like that. Do it right and never worry about replacing faulty stuff again. Trust me you'll thank yourself for going Old Man Emu. Not the cheapest route, but you get what you pay for. You could even go with this kit which is slightly cheaper http://toyteclifts.3dcartstores.com/Bilstein-Adjustable-lift-kit-with-5100-shocks_p_132.html
    ready6delta and Madox777[OP] like this.
  8. Aug 9, 2015 at 10:50 PM
    Madox777
    Madox
    RAM 1500 2014
    Ok, will definitely order OME shocks with front coils, for the rear I will probably leave the springs of Ironman along with Firestone air-ride kit. If 3" of lift is achieved with this set up I will not need to use spacers. Will also upgrade my tires for 285/60/18 size. Thanks for your help, guys!
  9. Aug 14, 2015 at 6:13 AM
    Madox777
    Madox
    RAM 1500 2014
    I am going to install 3/4" top plate spacers to get full 3" lift. And I would like to ask you if I need to have also differntial drop kit?
  10. Aug 14, 2015 at 6:16 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    No.
  11. Aug 14, 2015 at 6:25 AM
    Madox777
    Madox
    RAM 1500 2014
    Really? My Tacoma is 4wd
  12. Aug 14, 2015 at 6:26 AM
    geekhouse23
    So is mine..
  13. Aug 14, 2015 at 6:30 AM
    Madox777
    Madox
    RAM 1500 2014
    So what is purpose of installing such dif. kits for lifted Tacomas?
  14. Aug 14, 2015 at 6:32 AM
    geekhouse23
    The diff drop is useless on 05+ Tacomas. It "rotates" the diff in a way where not all the internals are lubed properly thus causing much more damage than good. To each their own though..
  15. Aug 14, 2015 at 6:11 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Ome vs toytec 3" lift ?
  16. Aug 14, 2015 at 7:15 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    OME all the way
  17. Aug 14, 2015 at 7:49 PM
    geekhouse23
