Advice - Sell As Is, Fix, value?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nearjetties, Jun 16, 2025.
  1. Jun 16, 2025 at 7:35 AM
    nearjetties
    nearjetties [OP] New Member
    Hi,
    Posting this for a friend since he’s less knowledgeable on car stuff. I’m a Land Cruiser nut so helping him out.
    He has a 2004 that has lost compression in at least one cylinder. See diagnostic video. 220k miles
    Upgrades:
    - arb bumper
    - FJ Cruiser 17” steelies and Falken Wildpeak AT3w. Tread on the tires are decent and the spare is unused
    - also has a cap with sport rack on it
    Needs: new engine, front suspension is tired from the heavy bumper, o2 sensor needs replacement, exhaust needs replacement, the tape deck doesn’t work (CD player and radio are fine).
    Professionally serviced on a regular basis. Full synthetic every 3-5k since he’s owned it. Purchased in 2019.
    The frame was replaced by Toyota under warranty not long before he purchased it.
    He’s in Massachusetts but has been diligent about having it Fluid Filmed and the undercarriage cleaned.
    He was already looking at Tundras because his family is growing.
    I don’t think the time/cost to fix makes sense but seems like a great start for someone that can do their own work or wants to do an LS swap.
    What do you think it’s worth as-is? Open to any and all advice.
    https://youtu.be/Q61v3LAQHiM?si=xb1rNaxNAELNXR-C
    more pics available when he gets the truck back from the shop.
    Here are some pics:
    3B68CC8F-A00C-436D-9A5F-635B63A9CE26.jpg 576110A5-A501-43F5-AD64-0C347C3ECFEE.jpg
    Including a pic of my truck for street cred :D
  2. Jun 16, 2025 at 11:17 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Pictures of the undercarriage are pretty important to assess value. How clean is the rest of the body, rust anywhere? Interior clean? Also, is it a manual or automatic transmission? These 4 cylinders are known to have head gasket issues. I also believe they need regular valve lash adjustment. Not sure if either of those impact compression but idk if it is for sure that this engine can’t be saved.
  3. Jun 16, 2025 at 11:38 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Could be as simple as a head gasket or a valve/seat burned. To claim it needs a total engine is BS.
    Since it likely runs, I'd bet all the issues are top end/head gasket, no need to replace or even pull an engine for that, pull the head, rebuild it or just buy an already rebuilt one and use the one in it as a core if they require one.
    Kevins60 likes this.
  4. Jun 16, 2025 at 11:50 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I think its not worth more than $5k, and that'd be best case senario, i.e. it having all the right options, and being in great shape outside of the engine problem and your buddy finding the right buyer.
    As others have already stated, the other ancillary factors can sway that figure a lot.
    - Does it have the rear E-locker?
    - Is it auto trans or manual?
    - How clean is the interior?
    - How clean is the body/paint/chassis?
    - Other than oil changes, how well maintained is it?
    If its automatic transmission, with not much maintenance history, with some crusty bits on the body panels, and some torn/stained seats AND its running on 3 cylinders, then its probably only a $2000-3000 rig.
    Pbfender15 likes this.
  5. Jun 16, 2025 at 1:16 PM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    There isn't really a calculus that works for everyone in these situations. If the owner has any emotional attachment to the vehicle a fix might be the right direction. If the equation is purely financial, then cut losses and move on might be best. Agree, value not more than $5k but that number really depends on the details. Could be significantly less depending on intertior and underside condition.
  6. Jun 16, 2025 at 1:24 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW..
  7. Jun 16, 2025 at 2:29 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Watched the video, the mechanic could be right but I’m betting he’s FOS or at least he’s not familiar with 1st gens. You can’t tell the engine is shot merely from the compression check. Like others have said really need to pull the head to see what’s what. He also recommended a custom exhaust shop, a Walker cat-back exhaust is less than $200. That said, the value really depends on the condition of the rest of the truck.
