Advice: truck jerks when I let off the gas
Discussion in '1st Gen. Tacomas (1995-2004)' started by foothill96tacoma, Jan 16, 2021.
  1. Jan 16, 2021 at 8:41 PM
    foothill96tacoma
    foothill96tacoma [OP] Well-Known Member
    1996 3.4L manual, 4x4, 337K miles
    So when I let off the gas when the truck is in gear at speed, there is a slight jerk that happens. I assume this has something to do with the idle/throttle. Where would you start to diagnose this?
    Things I've done recently: thoroughly cleaned the throttle body, replaced the IAC and TPS. Thanks in advance!
  2. Jan 16, 2021 at 8:48 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Is it a drivetrain feeling? I’d check the carrier bearing and ujoints that will do that when decelerating. When you take the load off it happens- replaced my carrier bearing and it stopped
    foothill96tacoma[OP] likes this.
  3. Jan 16, 2021 at 8:55 PM
    foothill96tacoma
    Ah that's interesting as I'm fairly convinced I have a carrier/u-joint issue (shuddering at highway speed) that I planned to fix mid-week. Hadn't thought of that, so thanks @hogeyphenogey !
    hogeyphenogey[QUOTED] likes this.
  4. Jan 17, 2021 at 9:35 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    My transmission mount went out a few thousand miles before where you are now. It would feel weird when I let off the gas, maybe peek at the rubber damper on your transmission mount. If that was the issue Go OEM replacement if you can
