Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by El Duderino 480, Jan 8, 2009.
  1. Jan 8, 2009 at 9:16 AM
    El Duderino 480
    El Duderino 480 [OP] "The Dude"
    Jeremy
    Oceanside, Ca
    Silver 08 PreRunner Sr5
    K&N 77 Series,Flowmaster Exhaust, OME N140's, OME 885's, Billy 5100's, Toytec AAL's
    so im going to afghanistan at the end of the year, and was thinking of what to do about my truck. my last deployment, i left my old car back home in phoenix with my mom and had her drive it once a week. would it be possible to just take the battery out, and leave it in front of my house??
  2. Jan 8, 2009 at 9:21 AM
    Joe B
    Joe B Well-Known Member
    Change the oil and filter.
    Add a fuel stabilizer.
    Go 7-8 lb of air pressure over door number.
    Leave windows cracked open.
  3. Jan 8, 2009 at 9:22 AM
    das56170
    das56170 Well-Known Member
    Temecula, CA
    2007 Tacoma Access Cab 4X4 SR5
    Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    The best thing to do would be to have someone drive it once a week. But, that's not always an option. If it's just going to sit there. Fill up the gas tank and put in some fuel stabilizer, then disconnect the battery.
    Good luck on deployment.
    Semper Fi
  4. Jan 8, 2009 at 9:22 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Tell you what, I wouldn't leave mine out for anytime, with or without a battery, OR it would be gone.. Being in the weather with no TLC, you may be unhappy when you get back.
    Depending on how long you will be gone, you may be able to rent some storage space to fit your truck or some locked place and buy a good quality cover. Tough call!!!!
    and yes...BE CAREFUL out their.
  5. Jan 8, 2009 at 9:25 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I'd say to pull your wheels / tires off and put the truck on jackstands... had a friend do that.
  6. Jan 8, 2009 at 10:20 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Bring it to South Carolina, we'll put it up on blocks for ya and give a nice shady spot out in the front yard. No one will even notice it.
  7. Jan 8, 2009 at 10:23 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Driving once a week would be a good idea. If not, I'm with Joe B on everything but the tire pressure. I would put your truck up on jack blocks.
  8. Jan 8, 2009 at 10:24 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    i think if it sits for a long time the tires will get flat spots and need to be replaced when you get back so putting it on jacks would be advisable. Change out the fluids, add stabilizer to the gas and run it through for a little bit so it circulates through the fuel system and leave the battery on a maintainer like a Batterytender. as mentioned, after sitting out in the weather it may not look as you'd like when you return. Good luck.
  9. Jan 8, 2009 at 11:01 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
  10. Jan 9, 2009 at 10:15 AM
    off road yota
    off road yota Razorback Fan
    Fayetteville, AR
    Offroad package
    Seat Covers, Exhaust tip, Roof Rack, All weather floor mats, Skid plate
    +1
