advice????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hollywood22, May 24, 2009.
  1. May 24, 2009 at 8:07 AM
    Hollywood22
    Hollywood22 [OP] Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Need some advice. I have had a 1st generation taco but had to get rid of it. It was the best vehicle I've had and was very disappointed when I had to get rid of it.
    I am now in a position to get a 2nd generation taco but am unsure what I should get with the budget I have.
    The way it looks now I can either afford an 05 Taco db TRD with over 100,000km/60,000m on it...or a 06 Taco dc base model with 70,000km/42,000m.
    It will be a commuter vehicle I need for work and will be rarely taken off road. However on the other side the TRD looks amazing and doesn't compare to the base.
    What do you think? and What exaclty am I missing out on If decide to go with the base?
    Thanks for your help. Cheers.
  2. May 24, 2009 at 8:35 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If you're not planning on doing much offroading you'll be fine with a TRD. Big time modifications make TRD a waste of money. If you're gonna haul people, go dbl cab... if you're gonna haul stuff... get the Long bed.... both togther like mine rack the price up a bit.
  3. May 24, 2009 at 8:36 AM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Get the TRD DC, More space you'll need sooner or later!
  4. May 24, 2009 at 8:37 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Brain about covered it.
    I have a base model Truck, I think it is fine. I wheel it whenever time permits, it is also my daily driver and when clean she gets tons of compliments.
