Advice:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrHaywardPool, Dec 6, 2020.
  1. Dec 6, 2020 at 4:01 PM
    MrHaywardPool
    MrHaywardPool [OP] New Member
    I have a question about testing an O2 sensor from a 2005 Tacoma with a 2TR-FE engine. I am following the FSM on page EC-27 near the bottom. It says to test the resistance for sensor terminals 1 to 2 which I did and it was in specs. Then it says test pins 1 to 4 which should be 10K or higher. I tried 2 different meters and I can't get any reading on either one. I have the rangeset to 20K and still nothing shows up on the meter. Am I testing this right or am I missing something. Thanks
  2. Dec 6, 2020 at 4:11 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    1/4 might be an open circuit (failed). Only going to get resistance between pins if it has continuity.
  3. Dec 6, 2020 at 10:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What is on the meter screen when you check between pins 1 to 4?
    It may read anywhere from 10K Ohms up to infinity or open circuit (OL) which IAW the manual is a good reading between pins 1 and 4. It depends on the meter.
    As long as it doesn't read less than 10K ohms you should be good.
    TnShooter likes this.
  4. Dec 6, 2020 at 11:25 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is what they are looking for on Pins 1 to 4 "A High Resistance Circuit" as it says 10K Ohms or Higher... That would include an Open circuit.
    T4RFTMFW[QUOTED] and 6 gearT444E like this.
  5. Dec 7, 2020 at 2:04 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Pins 1-4 are for the heater circuit. Even with the circuit failed it shouldn’t affect your readings once the engine is warmed up. Are you using a DMM or something like a Simpson to check for resistance?
