Advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kennyray, Jul 16, 2023.
  1. Jul 16, 2023 at 6:00 AM
    Kennyray
    Kennyray [OP] Member
    2022 tacoma
    I had a recent post about a leveling kit making the front of my Tacoma look too high. People suggest a 2” block and u joint kit for the rear. How many of y’all have done this and did it create any issues with the drive shaft or anything else? It’s my sons truck so I don’t want to do anything that might cause him issues. TIA
  2. Jul 16, 2023 at 6:05 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I would not run more than a 1” block in a Tacoma rear. People do run more.
  3. Jul 16, 2023 at 6:06 AM
    Matte Black burnt rust
    Matte Black burnt rust Well-Known Member
    2020 Tacoma TRD Off Road
    I recently put the Westscotts Designs TRD Off-road 3 inch lift on the front and a 2 inch block lift on the rear. No issues so far. Fingers crossed .
  4. Jul 16, 2023 at 6:31 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Welcome aboard :hattip:
    Every truck is different so no answer will be a guarantee except leave it at stock geometry if you don’t potential issues.
    Coming from a guy lifted 2.5” front and 3” in the rear and never really had issues.
    My honest answer is, you/he should love the truck and with the options out there make it what you want. Read lots on here before buying and you’ll be as ready for issues as possible.
  5. Jul 16, 2023 at 6:36 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The bigger the rear block, the more axle wrap you will have. Depending on how you or your son drives / off-roads, you might or might not notice the difference.
    Chew likes this.
  6. Jul 16, 2023 at 7:09 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    you did ask for advice.
    my advice is to leave the darn truck stock!
  7. Jul 16, 2023 at 11:21 AM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Look into a Headstrong Progressive add-a-leaf. Gives you 1 1/2" of lift and much better than a block. Unloaded it isn't much different than stock, but fill the bed or put a decent size trailer behind you and it is great. I run empty most of the time and like it, but towing a 3500# boat it works great.
