advise for install axle shims
Discussion in 'Suspension' started by brutalguyracing, Jan 24, 2010.
  1. Jan 24, 2010 at 11:14 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I have seen that for relocation plates. I have also seen shims with just a hole.
  2. Jan 24, 2010 at 11:17 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    yea i did not install the shims.....
    if anyone knows of any good quality shims....please let me know
  3. Jan 24, 2010 at 2:04 PM
    HBMurphy
    Paul
    So California Coast
    None
    I don't think it's a reflection on quality. If you think you need this shim just get new pins and cut to length.
  4. Jan 24, 2010 at 2:32 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    where do you get the new longer centering pins from with the extended head????
    everyone talks of them but no one knows......
    its not a matter of longer centering pins that u can cut its the round head on the oppisite side thats needs to be like 3/4 " lomger
    am i the only one who has these problems
    seems to be llots of guessing going on by folks on here.....
    i am sure i can not be the only person who has gone throught this.......
  5. Jan 24, 2010 at 2:46 PM
    HBMurphy
    Paul
    So California Coast
    None
    Go to a good parts store or a suspension shop. You'll have to cut them to length.
    Here is 4wp's line up...
    http://www.4wheelparts.com/Lift-Kits-Suspensions-Shocks/Leaf-Spring-Center-Pin.aspx?t_c=1&t_s=399&t_pt=4484
  6. Jan 24, 2010 at 3:00 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    see you keep saying cut them to length but we are not talking about the top of the centering pin under the bumpstop........its the bottom side that centers into the axle slot on the axle that is the problem......it is just a rounded end like a nub
  7. Jan 24, 2010 at 5:25 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Subscribed. Please post the solution, doing this one soon.
  8. Jan 24, 2010 at 8:48 PM
    drupp
    drupp Well-Known Member
    Pennsylvania
    '06 Access Cab TRD Off-Road
    Those shims have a pretty big square hole in the middle. If you position the head of the pin in the front part of that shim hole you should have just a little bit of the pin head protruding all the way through the shim. It's not much, maybe a 16th of an inch, just enough to catch the hole in the mounting bracket. You'll know you got it when it pops into place, like you described in one of your prior posts. Also, I think the head of the toytech pin is just slightly thicker than that of the stock pin.
    You can also buy shims that you stick the pin through, and bolt up with the spring pack, effectively making it part of the spring pack. But I didn't know this when I did mine, or I would have probably used them instead.
  9. Jan 24, 2010 at 9:44 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    do you know where i can buy them at????
  10. Jan 25, 2010 at 5:25 AM
    SamSter0077
    Katy, TX
    Bump
  11. Jan 25, 2010 at 5:51 PM
    drupp
    Pennsylvania
  12. Jan 25, 2010 at 6:02 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks i am goning to take a look at them now....
  13. Jan 26, 2010 at 12:55 AM
    tommyboy2929
    tommyboy2929 Active Member
    sacramento cali.
    2008 PreRunner SR5 Double Cab TRD Off Road
    Sport Hood(hood scoop), Chrome Nerf Bars, wheels, k&n intake, magnaflow exhaust, pioneer D3, focal speaker, and alpine pdx amp. soon to be more!
    im in the same boat as you... someone help please! i just put my lift on 2 days ago....
  14. Jan 26, 2010 at 7:20 AM
    SamSter0077
    Katy, TX
  15. Jan 26, 2010 at 10:19 AM
    #35
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    does anyone know what size centering pins to order if we want longer ones (longer than stock)?
  16. Jan 26, 2010 at 10:42 AM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    3/8" diameter.
  17. Jan 26, 2010 at 10:43 AM
    #37
    Simon2150
    Austin, TX
    Thanks man!!
  18. Jan 28, 2010 at 12:50 PM
    #38
    brutalguyracing
    F.U> GUYZ
    broken mods
    anyone got the fix for the longer centering pin length problem " not bolt length" depth of round head....
    can u just reverse the centering pin????
  19. May 26, 2010 at 4:26 AM
    #39
    frankybones
    frankybones Well-Known Member
    Frank
    Summerville SC
    2017 TRD PRO - CEMENT
    Was this issue ever resolved? I am thinking about installing this shim as well. Do you have to unbolt the entire leaf pack to install the shim? Does anyone have intructions on how to do this? I am not a mechanic so I am if this is something I can so myself in my driveway.
    Thanks
  20. May 26, 2010 at 5:44 AM
    #40
    SamSter0077
    Katy, TX
    I put the 3 Degree shims in from ToyTec.. didn't need long bolts or anything.. the Head of it is sitting in position barely.. but enough to function. Have had them on now for a while, and things seem to be working great. It's easy to do, and helps with and Driveline Vibes you might be encountering.
