advise for install axle shims
Discussion in 'Suspension' started by brutalguyracing, Jan 24, 2010.
  1. May 26, 2010 at 6:03 AM
    #41
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    You have to loosen your ubolts and once there is a large enough gap to slip in the shim, your good.
  2. May 26, 2010 at 11:08 AM
    #42
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    I used a washer with my centering pin so it would stick up higher through the shims.......for better axel allignment. My pins came with the TSB AAL.....ordered form ToyTec.......great product
  3. May 26, 2010 at 11:14 AM
    #43
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    What the hell...I've had my lift on for 3 months and I remember thinking the same thing during the install but just went with it. My centering pins did not go through the shim and into the bracket in the axle. I've driven 5000mi like that.
    Grr...I guess I'll be getting some 3/8" long bolts and nuts and doing this.
  4. May 26, 2010 at 3:47 PM
    #44
    twr437
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    It might not be necessary, but there sure isn't alot holding the axel in alingment if you don't.
  5. May 26, 2010 at 5:23 PM
    #45
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    can you think what would happen if you took a hard bump 4 x 4 ing and the axle shifts.......ouch
    its not worth it......
    i think this is a problem that is over looked often
  6. May 26, 2010 at 6:40 PM
    #46
    frankybones
    frankybones Well-Known Member
    Frank
    Summerville SC
    2017 TRD PRO - CEMENT
    pardon my ignorance but I want to make sure that If I do this I do it correctly. So there are two U bolts holding the leaf pack and one pin in the center. Do I just loosen or remove any/all of these to install the shim? I'm not a mechanic so I am afraid of messing with the leaf pack, it looks and seems like it could be a disaster. Also will I require an alignment after this is done?
  7. May 26, 2010 at 6:56 PM
    #47
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Loosen the Ubolts (or remove them) Fight with the shims to get the Alignment right.. bolt back up, no alignment needed. Pretty easy really, although with alcohol and darkness.. it can be tricky lining them up. :D
  8. May 26, 2010 at 6:58 PM
    #48
    twr437
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    You will have to completly lower the axel away from the leaf springs. Then use several C-clamps to hold the leaf pack together while you remove the centering pin. Place one or two washers on the centering pin, and reasemble with shim in place. You have to make sure the washer will fit inside the shim.
  9. May 26, 2010 at 7:09 PM
    #49
    SamSter0077
    Katy, TX
    Hmm, I didn't use washers? Oh Well, they lined up for me but more center pin would have been nice..:rolleyes:
  10. May 26, 2010 at 7:17 PM
    #50
    frankybones
    Frank
    Summerville SC
    ok so I am disassemling the leaf pack in order install the shim or can I just loosen the u bolts? Is it completly necessary to remove the pin? As you can tell im a little weary of this mod but it seems like its my next step.
  11. May 26, 2010 at 7:21 PM
    #51
    SamSter0077
    Katy, TX
    I did not have to loosed the Leaf, but I had the ToyTec centering pin.. maybe it's longer?
  12. May 26, 2010 at 8:02 PM
    #52
    brutalguyracing
    F.U> GUYZ
    broken mods
    no all you do is loosen the u bolts some "with no load on springs" and slip the shims in and retighten
  13. May 27, 2010 at 8:05 AM
    #53
    Toytec Lifts
    Rocky Mountains
    You could always pay a shop to install them for you correctly.
    Kolunatic likes this.
  14. May 27, 2010 at 8:21 AM
    #54
    SamSter0077
    Katy, TX
    Come on Darrick... where is the fun in that!:D
  15. May 27, 2010 at 9:00 AM
    #55
    frankybones
    Frank
    Summerville SC
    I could but I'd rather research and try it myself
  16. May 27, 2010 at 9:01 AM
    #56
    SamSter0077
    Katy, TX
    It's Easy Franky, just do it! Right Parts are key, and I have yet to go wrong with Toytec.
  17. May 27, 2010 at 9:07 AM
    #57
    twr437
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    If you only want to install the shim you don't have to remove the pin. If you want to add a washer or two for better alingment you will need to remove the pin.....you will probably need new pins.
  18. May 27, 2010 at 2:56 PM
    #58
    brutalguyracing
    F.U> GUYZ
    broken mods
    what he said^^^^^^^^^^^^^^
    it is so easy just do it
  19. May 27, 2010 at 3:15 PM
    #59
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    There is one thing that everyone is forgetting. When you out in a shim, it changes the angle of the springs. And the hole on the axle mount is just the right size for the pin on the leaf pack. So that being said, When you change the angle of that pin, it will no longer be able to enter the hole on the axle mount.
  20. May 27, 2010 at 3:17 PM
    #60
    HOSS454
    HOSS454 Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    i have some tuff country axle shims. they are 2* rather than 3* but the shim has a hole only big enough for the bolt to go through so that when you tighten the centering pin, the shim is tightened with the leaf pack and there is the rounded button thing that goes into the hole on the axle.. if you guys are interested, i got it at http://www.summitracing.com/parts/TFY-90012/...
