Advise on Rim Size
Discussion in 'Wheels & Tires' started by sac130e, Apr 18, 2011.
  1. Apr 18, 2011 at 10:37 AM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Going to run some BFG AT KO at 275/70/17 which should avoid trimming/rubbing issues with the 2-3" lift I will install.
    Have looked at the MotoMetal 955 and 956 rims, but they come in different sizes" 17x8 and 17x9.
    I understand the 6on5.5 and need for at least 4.5 BS, but not sure importance in the offset sizes listed. Tire spec stat for rims from 7-8.5 size so guessing the 17x8 rim would be perfect but listed offset range from:\-12mm, -6mm, 0mm and s high as +18mm.
    So which one is good for this tire and not cause rubbing issues on UCS or calipers?
    Thx
  2. Apr 18, 2011 at 10:38 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    17x8
    0 Off Set
    4.5 BS
  3. Apr 18, 2011 at 10:59 AM
    sac130e
    Scott
    Milton, FL.
    So this size will fit with no issues?
    What about the 17x9 with the -12mm offset. Do people have issues with these..whats the big difference?
    Thx
  4. Apr 18, 2011 at 1:50 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    There is no difference at all. Both are 4.5" backspacing. The 9" rim is just 1" wider.
  5. Apr 18, 2011 at 1:52 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    this :)
  6. Apr 18, 2011 at 2:12 PM
    sac130e
    Scott
    Milton, FL.
    Sweet thx, so a tire with the specs for a 7-8.5" rim will work on a 17x9 rim with no real issues?
  7. Apr 18, 2011 at 2:45 PM
    KPT
    09 Prerunner
    I wouldn't go outside of the tire manufacturers recommendation, but some folks do without any problems...
