Advise on slider install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Oct 2, 2011.
  1. Oct 2, 2011 at 8:00 AM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Getting sliders this week and was wondering what most of you are doing concerning your welds. Are you running a full bead along both sides and bottom edge of the frame plates or are you running 1" beads-2 per side and 2 on bottom. Your input is appreciated
  2. Oct 2, 2011 at 8:02 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I fully weld the whole frame plate when I install sliders as do most people.
  3. Oct 2, 2011 at 8:03 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Mine are fully welded to the frame
  4. Oct 2, 2011 at 9:51 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I would fully weld them. You want as much strength as possible
  5. Oct 2, 2011 at 12:00 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    thanks guys thats what i initially planed on doing
  6. Oct 2, 2011 at 12:01 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    how much clearance did you guys leave between the cab and the slider (for cab movement)
  7. Oct 2, 2011 at 12:05 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Welding is the preferred method on 1st Gen. frames because they are boxed-section, single-walled. The 2nd Gen. frame is C-section, double-walled. If welding is the only form of attachment, all the loads will be on the outer wall. You should have at least two bolts through the frame per flange, to spread the load to the inner wall too. Notice most of the OEM brackets, spring shackles, etc. are riveted?
    I think you are supposed to size the gussets to meet strength requirements, then notch the pinch weld at the bottom of the cab if necessary. At least that's what All-Pro instructions advise.
  8. Oct 2, 2011 at 12:10 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Wow didnt know they were double walled. thanks
