Advise pls 5100's maintain 3" lift
Discussion in 'Suspension' started by jigger1976, Feb 22, 2011.
  1. Feb 22, 2011 at 9:57 AM
    jigger1976
    jigger1976 [OP] Well-Known Member
    ontairo
    06 tacoma 4x4 ddbl cab
    3" lift, GRILL VENT VISIORS,CAP WEATHERTECH MATS
    just orded at set of 5100's and have some Q's.. Right now i have spring spacers in the front. now that i have orded the 5100's what do i need to mantain 3" of life.. if i set the 5100 at 2.5 and add a top plate??? or what?? advise guys:confused:
  2. Feb 22, 2011 at 9:58 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Uh.. whats a spring spacer?
  3. Feb 22, 2011 at 10:01 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes, get a 1/4" top plate spacer from Toyteclifts.com
  4. Feb 22, 2011 at 11:25 AM
    jigger1976
    ontairo
    spring spacer where now is 3" spring spacer is exacting what it says it a spacer between the spring and top plate. give u hight
  5. Feb 22, 2011 at 1:48 PM
    jigger1976
    ontairo
    Can i go with the top plate spacer 3/4 lift without damageing the shock
  6. Feb 22, 2011 at 1:51 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Also commonly refered to as a coil spacer
    That will give you 3.25" of lift. You will definitely need new UCA's to get your alignment right with that much lift. Also, top plate spacers do not damage shocks, but if they are large enough, they can damage ball joints by allowing the assembly to droop too far.
  7. Feb 22, 2011 at 1:56 PM
    jigger1976
    ontairo
    1/4" it is thx guys:D
  8. Feb 22, 2011 at 2:04 PM
    KPT
    09 Prerunner
    The 1/4" thick spacer that Ben mentioned will actually give you 1/2" of lift. so you'll be at 3". Spacers lift twice their thickness.
  9. Feb 23, 2011 at 8:54 AM
    jigger1976
    ontairo
    DOSE ANYONE KNOW IF THE 1/4 " TOP PLATE FROM TOYTEC IS EXACTLLY .250 I WOULD LIKE TO MAKE A SET MYSELF.
  10. Feb 23, 2011 at 9:40 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It should be. The lift ratio is 2:1. (might have that backwards) so it needs to be .250" if you want the full 3" lift with Billies maxed out. If you can make them yourself, go for it.
  11. Feb 23, 2011 at 10:46 AM
    jigger1976
    ontairo
  12. Feb 24, 2011 at 12:39 AM
    jigger1976
    ontairo
    anyone running 285/75/16 with just the 5100's at 2.5 can i get away with this?
  13. Feb 24, 2011 at 4:19 AM
    KPT
    09 Prerunner
    You need 4.5" backspaced rims or wheel spacers, and to trim some fender well plastic. and possibly chop the cab mount.
  14. Feb 24, 2011 at 7:42 AM
    skaterportland
    skaterportland Active Member
    Portland, OR
    2011 TRD OffRoad DC
    Spraypainted
    I have Eibach springs and 5100's set at .85 and .25 top spacer on drivers side = 2.5+ inch lift and am running 285/75/16 Duratracs. I had to bust out the grinder and cut a lot of plastic and a little wheel well. It supprised me how much I had to cut, and I need a little fine tuning. All that aside, I am so happy I went with 285/75/16's.
    I ended up buying 4.5" backspaced wheels, but was going to order Spydertrax from 4Wheel Parts with a 10% coupon for $180. Either way mission accomplished.
  15. Feb 24, 2011 at 7:47 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I just put a set of 285's on my taco yesterday. I'm running 5100's at 2.5. I trimmed a little plastic: trimmed a small corner of the rear of the fender flare, cut the little bubble out of the fender liner, and trimmed small piece of the corner off of the front of the fender flare. I haven't taken it offroad with the 285's yet. That will be the true test to see if I need to chop the cab mount.
  16. Feb 24, 2011 at 1:10 PM
    jigger1976
    ontairo
    SO LET ME GET THIS STRAIGHT? BECAUSE I DON'T WANT TO TRIM ANYTHING. IF I RUN 5100 AT 2.5 PLUS .25 SPACE WILL I HAVE TO TRIM ANYTHING??
  17. Feb 24, 2011 at 1:12 PM
    skaterportland
    Portland, OR
    2011 TRD OffRoad DC
    Spraypainted
    YES!
  18. Feb 24, 2011 at 1:13 PM
    jigger1976
    ontairo
    OK THEN I GUESS ILL HAVE A SET OF 5100'S FOR SALE.... DOSE ANYONE HAVE SUGGESTION THE FOR THE FRONT 5100'S PLUS WHAT???? TO MAINTAIN 3" AND NO CUTTTING AND CHOPPING??
  19. Feb 24, 2011 at 2:18 PM
    KPT
    09 Prerunner
    PLEASE STOP YELLING
    If you don't want to trim anything at all, then run 265's. Simple as that.
  20. Feb 24, 2011 at 3:56 PM
    jigger1976
    ontairo
    just because i use caps dosen't mean i'm yelling?? i'm just asking a Q's not switching tire there only 2weeks old,, i just want to know some suggestion on which direction to go.... now can i run the 5100 with my setup now with a diff. setting? or should i buy a set of spring? and if so then any recommendations...sorry guys if i came across the wrong way
