AEM 320 lph fuel pump install (works for OEM replacement)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brice, Sep 13, 2016.
  1. Sep 13, 2016 at 9:33 PM
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    AEM 320lph fuel pump install (works for OEM pump just don't modify anything)
    Step 1. lift bed for fuel tank access (bed bolts 17mm x4-6 depending on model)
    Step 2. fourwheeler tires. (prop it up)
    Step 3. Assort and remember connector and pipe locations
    Step 4. Undo pump bolts (8mm x8)
    Step 5. Here's what you're after.
    New AEM next to smol Toyota
    Step 6. Undo this/these
    Step 7. wiggle pump from grommet
    Step 8. Fully remove smol Yota
    AEM connector
    Step 9. adapt to Yota connector (I simply removed the Toyota wires and soldered to the left over crimps and shoved it all back into the plug) (AEM install only)
    Step 10. Modify pickup as necessary, and file down any burrs. (also blow through the tube to rid it of any metal dust) (AEM install only)
    Step 11. Install AEM to toyota connector and tighten worm clamps. (AEM install only) I had to modify the AEM grommet to fit the tacoma pump bracket.
    Step 12. Install AEM pre filter (AEM install only...obviously)
    Step 13. Reassembly is reverse of removal.
    Made it home, no fires!! :bananadead:
    (666th post :devil:)
    12TRDTacoma and Tucker771 like this.
  2. Sep 15, 2016 at 6:46 AM
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    great writeup! What is the benefit from this? and are you supercharged?
  3. Sep 15, 2016 at 7:11 AM
    Brice
    Brice
    Texas
    Well this pump will support up top 1000 hp (more than this truck will EVER see lol) and I'm turbocharged :D Its also much larger than OEM at 320lph
  4. Sep 15, 2016 at 7:11 AM
    Tucker771
    Tucker
    Raleigh, NC
    you lucky bastard:cheers:
  5. Sep 15, 2016 at 7:13 AM
    Brice
    Brice
    Texas
    Some may say that...;) Come check out my build, the link is in my sig
  6. Sep 15, 2016 at 7:21 AM
    Tucker771
    Tucker
    Raleigh, NC
    Good build! i might have to do this myself:burnrubber:
  7. Sep 15, 2016 at 7:22 AM
    Brice
    Brice
    Texas
    I must say so far its worth it :D
    12TRDTacoma likes this.
  8. Sep 15, 2016 at 7:33 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Best mod I ever did to my second gen (not counting the supercharger of course).
  9. Sep 15, 2016 at 7:33 AM
    Tucker771
    Tucker
    Raleigh, NC
    is it worth it for a N/A truck?
  10. Sep 15, 2016 at 7:36 AM
    Brice
    Brice
    Texas
    Nah not really, apparently the stock pump is good to about 9ish psi I'll be around 10-12
  11. Sep 15, 2016 at 7:36 AM
    Tucker771
    Tucker
    Raleigh, NC
    im just itching to either boost it or go diesel
  12. Sep 15, 2016 at 7:39 AM
    Brice
    Brice
    Texas
    Wait a while and I'll all the info necessary to turbocharge a tacoma composed into one thread :D or go diesel, that would be sick af.
  13. Sep 15, 2016 at 7:56 AM
    Tucker771
    Tucker
    Raleigh, NC
    theres a few people running the cummins 4bt and some running a Mercedes diesel but none that I know of that are boosting them
  14. Sep 15, 2016 at 7:59 AM
    Brice
    Brice
    Texas
  15. Sep 15, 2016 at 5:12 PM
    Tucker771
    Tucker
    Raleigh, NC
  16. Apr 13, 2018 at 6:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Is this pump still working well man, bout to SC my truck and want to get a good pump since mine is 22 years old.
  17. Apr 13, 2018 at 6:35 PM
    Brice
    Brice
    Texas
    Pump's still goin good. Never had an issue with it
  18. Apr 13, 2018 at 6:36 PM
    Speedytech7
    Sweet, which model was it, gonna go get one.
  19. Apr 13, 2018 at 6:37 PM
    Brice
    Brice
    Texas
  20. Feb 9, 2020 at 6:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
