AEM 340LPH fuel pump in 4 cyl 2TR-FE
Discussion in '4 Cylinder' started by BassAckwards, Nov 4, 2019.
  1. Nov 4, 2019 at 1:16 PM
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Has anyone installed an AEM 340LPH fuel pump in their 4 banger? Im wondering if the fuel pressure regulator can bypass enough of the unused fuel back to the tank, or if this pump is too much. Im n/a right now, but plan to go forced induction at some point and wanted to throw in an extra AEM 340 that i have laying around.
    Cheers,
    Robert
  2. Nov 4, 2019 at 1:58 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I'm rocking a dw200 which is around 250lph
    BassAckwards[OP] likes this.
  3. Nov 4, 2019 at 5:44 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    You might want to ask @05Taco4x4 or @MrCrowntown what they're running over in the Turbo BS thread. However, I remember reading somewhere (probably the Turbo BS thread) that the 2TR uses the same FPR that the turbo Supras came with, so you'll likely be fine.
  4. Nov 4, 2019 at 6:00 PM
    BassAckwards
    Thanks for the info yall. I will do some digging in the turbo thread and see if i can find out what theyre running.
  5. Nov 4, 2019 at 6:01 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I ran Aeromotive 340 lph on my first gen with the 2.7. seem to bypass enough fuel to me. Fuel trims are always good.
  6. Nov 4, 2019 at 6:42 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I can't recall but I believe that might be the pump I'm using, I think it's AEM and E85 rated. But I'm not using stock FPR
