AEM Fic6 on trd charger hard start
Discussion in 'Performance and Tuning' started by Goinmxn, Oct 28, 2015.
  1. Oct 28, 2015 at 6:05 PM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    3 linked, sas supercharged tons of armour
    Some of you may have read the post last year where I was having the problem with the URD calibrators, well I removed them and have gone with the aem tuner. I have just started playing with it and tuning. The first thing is it is very hard to start after warm, almost like timing is off. Changing values in the fuel map makes no difference, nor does timing. If I reduce map voltage at the starting areas of the map it does help, but not cure it. The truck starts perfectly without the aem, so I know it is an adjustment. I have the boomslang plug and play harness. Does anyone know if anything else is needed to be done to make the FIC work with the Tacoma? Like on the older tacos with resistors???
    Thanks!!
  2. Oct 29, 2015 at 8:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you tried contacting AEM's tech support with this issue yet?
    I have never tuned one so I cannot be to helpful.
  3. Oct 29, 2015 at 5:17 PM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    Update.... the problem is not related to the fic. I disconnected it and sure enough it will not start after warming up. I didn't let the motor warm up when I disconnected it the first time, just cold started it and assumed it was the fic because it started right away. So, I have to start looking at the toyota components now. Anyone seen something like this?? Runs great once its running but will crank forever before it starts once its warm.
    Thanks!!
  4. Oct 29, 2015 at 5:54 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Leaky injector(s), fuel pump going out, failed fuel pressure regulator, maybe a clogged fuel filter. Also try cleaning MAF and throttle body/IAC valve.
    Torspd likes this.
