Aero turbine
Discussion in 'Performance and Tuning' started by sharksfan27, Jun 3, 2012.
  1. Mar 14, 2013 at 1:56 PM
    #221
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    How are you finding the sound after cutting? I'm thinking of a dremel to cut the tip...
  2. Mar 14, 2013 at 2:22 PM
    #222
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    im in santa barbara....i love it but being 18...i like loud haha, definately didnt loose any power...like 25k ...ill pm you a pic after work.
  3. Mar 15, 2013 at 4:54 PM
    #223
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    It sounds much better, its still loud but not to the point of driving me crazy.
    I've got at a areo resonater in front of my AT. Depending on how much drown you can tolerate, ya might want one of those magnapack's in front of the AT.
    If you have access to a sawsall which is a reciprocating blade, it may be a easier way to cut the bell end off. Dremels are great for small job's but something like this may burn your dremel up. But if you do try with the dremel, have plenty of discs for stainless steal cutting.
    Be careful those dremel are pretty crazy at high speeds. Good luck.
    Its time for Jameson and Red Bull oh can't wait for the Irish car bomb...woot woot!
  4. Mar 16, 2013 at 7:42 AM
    #224
    2chains
    Calgary, Alberta
    ^^ ok, thanks for your help! The Jameson and Red Bull...not sure if i'll give it a go,lol
  5. Mar 27, 2013 at 12:44 PM
    #225
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    so whats louder?
    aero turbine 2525 or magnaflow offroad race exhaust ?
  6. Mar 27, 2013 at 2:52 PM
    #226
    RELLIM
    IOWA CITY IA
    Depends...do ya want a smooth or raspy sound?
    Anything that has packing is smooth sounding, the aero is has no packing.
  7. Mar 27, 2013 at 2:59 PM
    #227
    RELLIM
    IOWA CITY IA
    I put a 3.5 x 12in ss tip on my tail pipe.
    It made a big difference in sound. It smoothed the sound out and cut out a lot of the interior resonation.
    Ir was a bit surprizing, but needed.
  8. Mar 28, 2013 at 9:22 AM
    #228
    2chains
    Calgary, Alberta
    ^^thanks for the update!
  9. Jul 5, 2013 at 3:18 PM
    #229
    silverbulet93
    silverbulet93 Member
    Tyler
    Ferndale,WA
    2012 TRD Offroad. Little bit tricked
    LED headlights and fogs, 3" spacer lift 285/65/18 toyo at 2s, Kim's rock stars, urd TCAI, MBRP exhaust, 2 10" Rockford fosgate p3sd4s, every other light replaced with LEDS, blacked out badges
    Hey where's a good place to order an aero turbine from?
  10. Jul 5, 2013 at 8:19 PM
    #230
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
  11. Jul 5, 2013 at 9:18 PM
    #231
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    You're absolutely right. :)
    I learned what you said by personal experience when I put a Magnaflow on my 2.7 and it lost some low end torque, It was a straight through model.
    So I put the stock muffler back on. It's not worth losing low end torque just to gain sound. It also resonated at 2,000 which is where I run the engine all the time. After a while it got on my nerves.
  12. Jul 6, 2013 at 6:35 AM
    #232
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  13. Jan 26, 2014 at 8:50 PM
    #233
    ryan c
    ryan c rookie
    ryan
    661 Lake Ez
    '06 4x4 swb dc
    2.5" lift in front, aFe air intake, anytime foglights, cut 9" off antenna, superwhite headlights, spintech exhaust, med. tint in the front, weathertech floorliners and caltech seat covers, dashtek dash cover, CHLM, debadged and destickered,
    Just ordered an AT2525 from ebay. Should have it installed by Friday. I went with the 2525 instead of the XL cause Some of the sound clips of the XL sounded iffy. I know itll probably be too loud but this way I can play around with different resonators to get the right sound. More expensive but I don't want to do this again. I have a spintech and hate it.
  14. Oct 25, 2014 at 12:17 PM
    #234
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    Is this a diy install or take it to a shop?
  15. Oct 25, 2014 at 3:53 PM
    #235
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Depends. Do you know how to install a muffler? If you have to ask... its probably a job better suited for the shop
  16. Oct 25, 2014 at 10:01 PM
    #236
    1stgen
    18 SR5
    Taking it to a shop then. I have no clue.
  17. Nov 12, 2014 at 9:27 PM
    #237
    MEMO CAMPOS
    MEMO CAMPOS Well-Known Member
    Westminster, Ca.
    05 PRERUNNER
    TC Upper Arms, ICON coilovers, Camburg spindles, AP standard leaf packs, ICON Resi.'s, AFE intake, Magnaflow Magnapack, Defiant Light Bar with PIAA 580's, 6K HID's top and bottom
    Ordered my 2525XL !! Hopefully not to loud. Has anybody had the material in the built in resonator degrade and get louder?
  18. Nov 13, 2014 at 1:17 PM
    #238
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ^^ i never did. loved my 2525xl. moved up to a 3030xl actually.
  19. Nov 18, 2014 at 12:24 PM
    #239
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    Just got my AT 2525Xl installed!! Wow do I love it! Swapped out a 24" MF in which ended up being to quiet. This however is a perfect balance between too quiet and too loud. Just as they describe " medium" sound level.
    Overall I highly recommend this muffler!!
  20. Mar 7, 2015 at 9:12 AM
    #240
    1stgen
    18 SR5
    Is there any cutting involved to get the aero one to fit in the same place as the stock first gen one?
