Aero turbine
Discussion in 'Performance and Tuning' started by sharksfan27, Jun 3, 2012.
  1. Jul 17, 2012 at 7:59 PM
    #141
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    this is straight off of urd's website for the 3" exhaust (which i have)
    "When URD designed this Cat-Back system we had our own supercharger system in mind as well as other forced induction systems. We were concerned that the large 3" diameter piping might be too much for normally aspirated combinations and might lose some low end power. We did some dyno tests and we were very pleased to see that there was no significant low end power penalty when installed on a normally aspirated engine. We were even more pleased to see the nice gains in the entire RPM range. So, for you normally aspirated folks .... this system works great."
  2. Jul 17, 2012 at 9:35 PM
    #142
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    With a 3 in system you should have a lower exhaust note.
    Since areo mufflers make a low volicity pull on the exhaust, I think it work good with a 3" cat-back.
  3. Jul 27, 2012 at 1:00 PM
    #143
    sleeper8406
    sleeper8406 Well-Known Member
    I just got my AT2525XL welded on at a shop. I had them keep the stock exhaust location. I'm not sure if I like it or not. It drones pretty bad around 1.5k rpm. Which is cruising speed for me most of the time. Will it get better with time?
  4. Jul 27, 2012 at 2:13 PM
    #144
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The tone will change a little over some time. How much? I cannot say.
    You could always add in a resonator down the road if it is still to much drone for you.
  5. Jul 27, 2012 at 2:41 PM
    #145
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    It will change tone... but the change is negligible honestly. If you don't like it now ill recommend a resonator.
  6. Jul 27, 2012 at 6:32 PM
    #146
    sleeper8406
    I guess Ill have to get a resonator then. Or save up for a URD catback.
  7. Jul 28, 2012 at 7:44 AM
    #147
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Get the resonator. Add it in right after the y-pipe to catback flange. You should be ble to fit a nice 18" long one in right there. Just make sure to double check you available room.
    Adding it in at that location is the best place, and will make a huge difference in exhaust noise/rasp/drone.
    Unless of course you really have you eyes set on the URD catback.
  8. Jul 28, 2012 at 1:30 PM
    #148
    sleeper8406
    Any recommended brand for the resonator?
  9. Jul 28, 2012 at 1:45 PM
    #149
    memario1214
    Colton
    Missoula, MT
    Vibrant is the brand I recommend
  10. Jul 28, 2012 at 6:52 PM
    #150
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
  11. Oct 15, 2012 at 2:46 PM
    #151
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I was thinking of putting in two resonators, one on each side of the y-pipe before they meet, after the secondary CATs, purely for more sound reduction. What do you think of that set up?
  12. Nov 24, 2012 at 1:26 PM
    #152
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Are most of you guys with the at2525xl's installing it at the stock muffler location? Just ordered mine and wondering how/if that affects the cabin drone...just wondering after sleeper8406's post
  13. Nov 24, 2012 at 5:15 PM
    #153
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    I have mine installed at the stock location but I honestly can't tell if its that or the fact I have it dumped before the axle. I'm used to drone from the setup I had on my 03 and even so the AT drone is less than that. Like others have said a resonator should help.
  14. Dec 2, 2012 at 7:09 AM
    #154
    2chains
    Calgary, Alberta
    AT2525xl is installed, nice tone @ idle but fair amount in cab noise accelerating @ 60kmh-68kmh(40mph) 1900rpm range. Doesn't seem to drone @ 1500rpm. update:: Now have drone @ 1300rpm after 400km's driving
  15. Dec 2, 2012 at 7:24 AM
    #155
    sleeper8406
    I no longer have the drone. I didn't add a resonator though, I just chopped it right after the axle. I am quite pleased with the exhaust note now. I think the drone had a lot to do with the fact I have an automatic.
  16. Dec 2, 2012 at 12:47 PM
    #156
    2chains
    Calgary, Alberta
    thanks for the update, can anyone chime in on any known issues performance or otherwise with chopping after the axle and not having exhaust extended @ stock location? total noob here but, I was under the impression more noise came from the exhaust pipe opening so chopping under the truck would cause more in cab sound...
  17. Dec 2, 2012 at 6:39 PM
    #157
    sleeper8406
    Honestly, after I chopped mine the in cabin noise was reduced along with the drone. I think it was just how the pipe resonated at that rpm range. I changed the pipe so now it resonates differently. I could have gotten an additional resonator but I just didn't feel like spending money on something that may or may not have worked.
  18. Dec 2, 2012 at 8:37 PM
    #158
    RELLIM
    IOWA CITY IA
    Ya could install it per instructions from the manufacture.
    For maximum performance and fuel economy install the aeroturbine
    with 12" of strait pipe in front and behind the muffler.
    Their is a direction of flow to this muffler, everyone knows this right??
  19. Dec 2, 2012 at 8:48 PM
    #159
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Considering buying one of these and I think they sound great!
    But after reading a few posts from this thread, everyone is adding additional resonators to dull the drone. Is the sound an annoyance after a while or what? If your unpleased with it, what would you change to? I don't want a muffler that will restrict airflow like the flow masters but want a nice deep sound...
  20. Dec 2, 2012 at 8:55 PM
    #160
    jeffallen29
    jeffallen29 Well-Known Member
    jeff
    northeast Tennessee
    Do any of you guys run this Muffler and a Resonator on an otherwise Stock 4.0 with all 4 Cats and Tailpipes?I would like to run my exhaust this way but with 2 1/2" exhaust,1 muffler and Resonator Y Piped with dual tailpipes for looks.I think it would sound good this way without being Overly Obnoxious.I like some sound to my truck but I dont want it obnoxiously Loud and Droning on the highway.Anyone have any Videos of their exhaust this way please post them.I dont care if you have single or dual tailpipes im just curious of the sound of a stock 4.0, all 4 Converters in place,Aero muffler and Resonator WITH single or dual tailpipes.I think this may be the sound Im looking for on my Taco.
