AFE Cat back exhaust rant.
Discussion in 'Product Reviews' started by steeds, Dec 13, 2013.
  1. Dec 13, 2013 at 7:13 PM
    steeds
    steeds [OP] Well-Known Member
    ryan
    calgary
    2013 black tacoma access cab trd offroad
    6" pro comp stage one lift tinted windows blacked grill decals removed 3" AFE cat back exhaust stage 2 dry AFE air intake.
    yep well the AFE exhaust pissed me off all day!!! they didn't even weld it correctly..one of the anchors was welded wrong...(it was lower/90 degrees from where it should have been)
    sooooooooo i brought it to the place i bought it from and they had to cut the anchor and then make/reweld a new one to replace it!!!!
    the intake i bought with it better not go wrong or i'll be even more pissed with them.
    when i called AFE headcourters they said that it wasn't fully tested and were sorry...well geee, if you do not have it done right, why would you sell it to people !!!!!!
    just have photos of where they cut it/with the new anchor and exhaust back on/side view to see the proper way the anchor should have been welded on ( facing towards the front of the truck, not 90 degrees to the right side of the truck.
    a short incab sound of the truck..not the best cause it was on my phone but you'll be able to get the idea.
    aside from the hick up from them, the exhaust does sound good and isn't loud in the cab unless your at certain rpms...which would be typical i'd think with different brands.
    http://www.youtube.com/watch?v=pkZMiHOcow0
  2. Dec 31, 2013 at 7:33 PM
    Pepe98
    Pepe98 Love moding vehicles as hobby
    Paul
    Dayton, Ohio
    SR5 that's begging for mods
    1st Update: 500 miles Rugged Ridges Matts, Dimming rear view mirror with comp/temp, AeroForce Tech Interceptor Gauge, Aeries Professional Bull and Nerf bars, LED Lighting complete in-Cab, LED DRLs, AMP Bed Xtendr, Extang Trifecta Signature Series Tonneau, Rigid Ind LED Lighting 30" E and 20" SR series, Rigid LED Grill insert, Katskinz Leather Interior, Custom 100amp Electrical Sub Panel x2 (Engine bay and Interior), custom vinyl bed side, interior accent lighting galore (Oznium), OTTRAW, switches, under hood lighting, Red Line Elite hood struts, Power Pop-n-Lock, Under Bed Rail Lighting (switched), Custom Tinting... More to come
    I have exact setup you do. (Exhaust and intake) I bought it from auto anything so I am about to go check to we where my hanger is welded. Thanks for the heads up.
  3. Dec 31, 2013 at 7:51 PM
    Pepe98
    Paul
    Dayton, Ohio
    Shit, looks like it is the same issue on mine. I am about to get ticked.
    Even the instructional handout has it wrong on the diagram.
  4. Jan 1, 2014 at 8:56 AM
    steeds
    ryan
    calgary
    wow thats such a piss off..i heard alot of this company but not so much for negative.
    so for yours they welded it on wrong like mine and they added another one haha
    think that maybe they might have sent you a different one or they are fucking morons.
    but it was a quick fix, i just went to the company where i bought it and they fixed the problem.
    good luck haha
    tell me how it goes.
  5. Jan 1, 2014 at 9:06 AM
    na8rboy
    na8rboy Well-Known Member
    Toyota changed that hang location from 12 to 13. So that exhaust would work on a 12 fine. This is why you guys are having this problem, afe never updated it, or there trying to sell off leftover stock.
  6. Jan 1, 2014 at 9:23 AM
    Pepe98
    Paul
    Dayton, Ohio
    Thus why mine has two, to cover all years. Kind of a screwed up shortcut on their end but it works I guess and since it's underneath, only mechanics will see. Knowing my type A persona I will take the 30 seconds with a cutting wheel and get rid of the old one.
    aFe still has a good rep and their stuff is pretty squared away. You know the TRD intake is the same as the one we have on ours. Just put the TRD mark on it for Toy.
  7. Jan 1, 2014 at 8:02 PM
    steeds
    ryan
    calgary
    ...clearly. haha
  8. Jan 1, 2014 at 8:05 PM
    steeds
    ryan
    calgary
    i wanted a new intake so i got one..can care less if it was the same or not.
    plus afe actually sent me a new filter for the intake..not like it would do much...only saved me maybe 30 bucks..but it was nice of them to offer.
    still it's a year after the truck has come out...get your act together guys, how many other exhaust have they fucked up haha
    i never would have thought they would have mine fucked up..let alone after im sure others including myself gave them input, that they would have this problem with yours also.
    sucks but when it's all said and done, i like the exhaust and sound forsure.
  9. Mar 27, 2014 at 8:42 PM
    R61988
    R61988 Well-Known Member
    Nick
    Paso Robles, CA
    2013 TRD Sport DCLB 4x4
    OEM Replacement King Coil-overs . AFE Mach Force XP Cat-Back Exhaust System. AEM dry flow drop in filter. Cooper Discover AT3. KMC Addict 17" wheels. VLED LED lights: Switchback DTRL/Turn Signals, Fog Lights, Reverse Lights, license plate, map, dome, vanity.
    Well to add to this topic. I just bought my AFE 2.5" Mach Force Cat back. For my '13 Tacoma And sure and shit once I was installing parts my rear hanger had the same prob. Had to take it to shop to weld a new hanger that was pointing right direction. I tighten the clamps as much as I could and the rear pipe was still spinning at the muffler connection. So had to spot weld both connections to prevent the pipes from spinning.
    Overall awesome sound little notice in power. Not to loud and not too quiet. Just a good exhaust system. Well besides the hanger fuck up. Ha
  10. Mar 28, 2014 at 4:37 AM
    Pepe98
    Paul
    Dayton, Ohio
    Ok, I could add pages of problems with the customer service and attention to detail in their engineering and marketing departments. AFe in the corporate structure lacks integrity and flat out lied to me, and now, after months of trying to correct this issue, I have gotten no where. Once I got a few Tacoma's lined up, they flat out stopped communicating with me.
    So now I am going after them via my attorney, BBB (of which they are not members and have a bismal record on), etc. i have a few models/ makes of sport and muscle cars and thought I would give aFe a try.
    I am not saying their products are crap, in fact I like them once I fix their engineering mistakes. What I can not, and will not tolerate is a lack of integrity in the business model and employees. So,I will do what I can to help others out by getting the word out there.
    If you don't mind getting a product that you pay a lot of your hard earned cash on, then have it have problems, try and work it professionally through their customer service, get lied to and then told to send it back to the company you bought it through 3 or 4 months later who had NO fault, then aFe is just your kind of company. There are plenty of other companies I would rather give my business to who make comparable or better products.
  11. Apr 20, 2014 at 7:40 PM
    crusader1
    crusader1 Well-Known Member
    Al
    SC Upstate
    06 PreRunner TRD#1/'73 Datsun 240Z Orig. Ownr
    None yet...just warmin' up
    Sorry all you guys are having such difficulty with your cat-back systems. I feel I really lucked out by reading of AERO Exhaust via this Forum, and acting on it. Working with "Jordan," I ordered his #2525 for my '06 PreRunner Extended Cab V6, and couldn't be happier with the quality, looks and sound of it.
    The massive clamps were the only unpolished part, so I flicked on the buffer wheel, grabbed the stick of SS polish and had them reflective in short order.
    The whole system glows like a jewel under my refurbished undercarriage, and I still haven't replaced the spare (getting powdercoated), tow hitch assembly (Rhino-coated) or rear bumper...I really like the view under there!
    Another TWF tip led me to "Level 8" wheels at DiscountTireOnline, so their 17x8.5 "Punch" in Anthracite/machined are on the way. Working on the 5-piece billet grille assembly, now, and planning to powdercoat the calipers "Ferrari Red" and blast the drums for black caliper spray.
    You guys have lit a fuse I can't extinguish, and I really treasure this site.
    Muchas gracias, Amigos!
  12. Sep 12, 2014 at 11:14 AM
    steeds
    ryan
    calgary
    nice nice,
    yeah other then the fuck up with the hanger, the company and product/sound is great. i still love the sounds of the intake/exhaust.
    i've had it on close to a year and no problems.. I'm glad that AFE sent me a new filter as after 40,000km with that filter,rather then cleaning it i'll just throw the old one away and put the new one one. quick and easy.
    but yes i still do enjoy both products from AFE. soon to be more mods, just unsure as of now what to get.
  13. Sep 25, 2014 at 10:04 AM
    Sgt Jmack
    Sgt Jmack Well-Known Member
    Jeremiah
    New Orleans, LA
    14 Sport Dbl cab L/B
    3" Revtech, Undercover flex.
    MPH or MPG improving?
  14. Sep 26, 2014 at 7:43 AM
    steeds
    ryan
    calgary
    your fuel got better ?! i wish. and i didn't notice any power change in mine..if anything there is a bit of a delay when i hammer on the gas, but then it kicks in to make it seem like there is more..but I'm not sure.
    i wonder if my back pressure if off because my exhaust now is a 3" instead of 2" or 2.5" ? anything know if this could be possible ?
  15. Sep 26, 2014 at 6:39 PM
    Sgt Jmack
    Jeremiah
    New Orleans, LA
    Did you have your computer tuned to let it know you made changes to the intake and exhaust?
