AFE Cold Air Intake Issues HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ravistae, Dec 18, 2015.
  1. Dec 18, 2015 at 6:51 PM
    Ravistae
    Ravistae [OP] Well-Known Member
    Travis
    2015 Tacoma DCSB
    AFE CAI keeps throwing check engine light. Second time now in two days. Checked and double checked all connections and sensors. Everything is secure so why does this keep giving me check engine lights? My buddy mentioned I may need to take truck to the dealer and have ECU programmed for the CAI!!
    ANY SUGGESTIONS?
  2. Dec 18, 2015 at 6:55 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    What code is it throwing?
  3. Dec 19, 2015 at 10:21 AM
    Ravistae
    Travis
    2015 Tacoma DCSB
    Do I have to go to the dealer to get the code or will a place like advanced auto suffice?
  4. Dec 19, 2015 at 10:22 AM
    Longboard1110
    San Jose
    A few things
    Autozone could probably do it for free.
  5. Dec 19, 2015 at 11:39 AM
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    Did you unplug the neg battery cable for a little while and then put it back on?
  6. Dec 19, 2015 at 12:54 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    Yea unplugged the battery to clear the code and it runs fine. However it did it again yesterday. Just trying to figure out why this is happening. Has anybody else had issues after installing AFE Cold Air Intake or any intake for that matter?
  7. Dec 19, 2015 at 12:55 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    So the dealer can do nothing to calibrate ECU for an aftermarket intake?
  8. Dec 19, 2015 at 12:55 PM
    .45 JHP
    .45 JHP Doesn't even own a Tacoma
    37.3582115,-121.9281197
    2015 4Runner TRD Pro
    No one can help unless you pull the code.....
    Check your vacuum hoses, MAF sensor plugs. Until we know more there's nothing we can really help with...
    Lord Helmet likes this.
  9. Dec 19, 2015 at 12:59 PM
    Rusty15Tacoma
    Rusty
    San Diego
    I installed mine about a month ago. No issues. I also have a 15'. Start over and go through your lines. If that doesn't do it, check the air pump extension. I didn't like the way it isn't weather proof so I just cut the tape on my stock harness, which freed up enough room to use the factory harness.
  10. Dec 19, 2015 at 1:06 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Either an air leak somewhere downstream of the MAF sensor (which can cause a lean condition), or the MAF sensor was dirty or damaged during the swap. Was the AFE CAI bought new? Are you using the two white plastic spacers on the MAF sensor with the O-ring nicely seated?
  11. Dec 19, 2015 at 1:51 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    Will check and double check all connections hoses and sensors. I'll do a follow up with you guys. Thank you
  12. Dec 19, 2015 at 2:06 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    It's dry
  13. Dec 19, 2015 at 2:11 PM
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    Iv heard of a few ppl on here just letting it stay on for a few days. After a few days the ecu gets the air fuel mixture back to normal and the light goes off. But I would check for vacume leak and disconnect battery one more time. Iv had multiple afe intakes and never a code thrown. On my fj and also on several of my tacomas.
  14. Dec 19, 2015 at 2:12 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Sub for outcome
  15. Dec 19, 2015 at 2:14 PM
    1rooster
    Georgia
    2007 Tundra crewmax
    +1
  16. Dec 19, 2015 at 2:24 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    Sub for outcome?
  17. Dec 19, 2015 at 3:05 PM
    Longboard1110
    San Jose
    A few things
    Exactly, it may be unrelated and just a time coincidence, or something was not installed correctly.
  18. Dec 19, 2015 at 3:06 PM
    Longboard1110
    San Jose
    A few things
    Also it's always good to have your own code reader.
  19. Dec 19, 2015 at 5:34 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    The smog pump plug extension that comes with the intake only extends 2 wires if I remember correctly but the stock plug actually has 4 wires. Any chance that might cause issues for someone?
  20. Dec 19, 2015 at 10:31 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    Could always go back to stock to confirm. It's a very well made cold air intake already.
