AFE Cold Air Intake Issues HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ravistae, Dec 18, 2015.
  1. Dec 19, 2015 at 11:48 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    Sub'ed to see what it is.
    We need the code.
  2. Dec 20, 2015 at 3:41 AM
    Ravistae
    Ravistae [OP] Well-Known Member
    Travis
    2015 Tacoma DCSB
    Fingers crossed check engine has not gone off again...Im really hoping the ECU has it figured out on its own. That would be ideal however, if I get another code I will get it checked and follow up with you all.
  3. Dec 20, 2015 at 4:16 AM
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    Still haven't said what code
  4. Dec 20, 2015 at 6:19 AM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    Get the code read....
  5. Dec 20, 2015 at 8:16 AM
    Ravistae
    Travis
    2015 Tacoma DCSB
    I will get you the code if it pops up again so far it has not come back on.
  6. Dec 20, 2015 at 8:29 AM
    Ravistae
    Travis
    2015 Tacoma DCSB
    I didn't know you could get a previous code if the light isn't currently on. I will do that.
  7. Dec 20, 2015 at 10:52 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I have had my AFE Stage 2 SI for about 3 yrs and not one issue. I'm betting on the install error here, probably the MAF sensor isn't sealed correctly with the white spacers that is included with the kit. That will cause a leakage and throw the CEL. Everything else is self explanatory including the smog pump which is relocated and plug and play.
  8. Dec 25, 2015 at 7:34 AM
    Ravistae
    Travis
    2015 Tacoma DCSB
    It was the plug extension piece for the smog pump. Was able to use factory connections by cutting electrical tape that gave me enough length
