afe or injen cai for 2.7 09 taco
Discussion in 'Performance and Tuning' started by l4taco09, Jun 16, 2012.
  1. Jun 16, 2012 at 1:07 AM
    l4taco09
    l4taco09 [OP] New Member
    california
    09 sr5
    I'm still debating which one to get.
  2. Jun 16, 2012 at 1:29 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    +1 for aFe
  3. Jun 17, 2012 at 9:45 PM
    l4taco09
    california
    09 sr5
    do they make the intake where it's located infront of the radiator for the 2.7l?
