AFE or K&N for the?
Discussion in '4 Cylinder' started by Steve E, Apr 8, 2009.
  1. Apr 8, 2009 at 10:19 PM
    Steve E
    Steve E [OP] Well-Known Member
    Southern Missouri
    2014 TRD Sport DCSB 4x4
    I have an 08 Access Cab and have started mods, K&N so far, removal of 2nd air filter. Thinking about a header next. I have more than one person saying not to use the K&N was wondering if I should sell it and get the AFE filter? Thanks for any advice.
    Steve E..........
  2. Apr 9, 2009 at 3:30 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It depends.....
    I've owned many K&N filters over the years and never had any problems with them. You can't just pop it in and leave it. YOu have to keep it cleaned and cleaned regularly. You have to be careful not to over-oil it.
    Over oiling it causes the oils to get on the MAF sensor (a major complaint).
    People who don't keep it cleaned - will notice dust getting past it (another complaint). You also need to make sure it's seated in your airbox properly.
    The oil is what filters the fine dust. Once the oil is 'full' (dirty), it can't filter anymore.
    When I owned K&N's - I cleaned them twice a year. YOu have to make sure they're fully dry before you oil them - so I'd always have a spare paper filter to put in the vehicle while the filter was drying (a full day usually).
    Currently, I have an AFE. I wanted to try it. I like it....but I honestly don't think it allows as much airflow as the K&N does.
    If you're looking for maximum airflow gains- I'd go with the K&N.
  3. Apr 13, 2009 at 8:25 PM
    Steve E
    Southern Missouri
    Thanks for the info, I have the K&N so I guess I'll keep it.
    Steve E.........
  4. Apr 14, 2009 at 7:15 AM
    Steve E
    Southern Missouri
    I believe I will keep the K&N while we are stationed out here in Kommiefornia at least. Thanks.
    Steve E.......
  5. Apr 14, 2009 at 10:06 AM
    Steve E
    Southern Missouri
    Unfortunately it is all City driving around here.
    Steve E.........
  6. Apr 25, 2009 at 9:40 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
  7. Aug 25, 2009 at 12:13 PM
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    Just dropped in a K&N replacement air filter. I immediately noticed that the idle was way smoother...guess all that extra air helps out ;).
    Put a K&N in my wife's TJ a year ago and have only washed and re-oiled it once. One question about reoiling...are you supposed to use a cloth to re-oil or are you supposed to spray it on or some other method? Just curious as I applied the oil with a cloth on the intake side of the filter.
  8. Aug 25, 2009 at 12:25 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    FYI a member here has found that ALL K&N filters (whether it be CAIs, drop ins, etc) produce silica levels in oil that are VERY high.
    They are very poor filters
  9. Aug 30, 2009 at 1:01 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    any results about this with the AFE filters?
  10. Aug 30, 2009 at 1:08 PM
    DanGer
    Not yet, I believe he said he was going to stop the constant testing until worked picked up
  11. Aug 30, 2009 at 1:09 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I run a K&N on my DR650 Suzuki and have been happy with although was very careful in making sure it had good seal with foam ring mounting surface and I also used the red Pre-Filter in addition. It is also oiled. I don't have any scientific evidence to their actually effectiveness but have noticed some people have mentioned fines getting past in very dusty conditions. I only ride ride on the street. :rolleyes:
    Motoretro
  12. Aug 30, 2009 at 1:10 PM
    DanGer
    It doesnt matter, the microscopic dust they let in constantly are in any driving conditions
  13. Aug 30, 2009 at 1:12 PM
    Janster
    Jandy
    Lancaster, PA
    You have to take the filter out completely. Spray the oil (as per the instructions) directly onto the filter and the oil WICKS into the paper material.
    The one thing I did ....I had a spare paper filter that I'd put in the vehicle while I was cleaning the K&N. I let the K&N sit overnight to dry completely before re-oiling it. If the filter is wet when you re-oil it, the oil can't WICK into the paper and it won't filter properly.
  14. Aug 30, 2009 at 1:15 PM
    Janster
    Jandy
    Lancaster, PA
    Is that the same as microscopic germs and even moisture in the air??
    Anything microscopic (or even bigger than that) will get burned up and will exit out the exhaust. :p:p
  15. Aug 30, 2009 at 4:21 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Not necessarily.
  16. Aug 31, 2009 at 4:16 AM
    Janster
    Jandy
    Lancaster, PA
    So, the microscopic germs and dust impregnate your pistons? Or do they attach to your valves & multiply in your exhaust? :D;)
  17. Aug 31, 2009 at 5:23 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    First, not everything is burned during combustion. Second, there is leakdown. So every time you kill the engine, you have at least one or two cylinders in the compression stage. The pressure that is in these cylinders (which includes your microscopic germs) is "bled" into the crankcase through (or by) the rings. The leakdown contains all those "germs" or particulates, which is how it gets into the oil.
  18. Aug 31, 2009 at 9:26 AM
    Janster
    Jandy
    Lancaster, PA
    And why you change your oil every 5000 miles - to get rid of the crap in the oil.
    A little 'dust' past the filter isn't gonna be catastrophic like everyone is making it to be.
  19. Aug 31, 2009 at 9:32 AM
    sloancallaway
    sloancallaway Well-Known Member
    Sloan
    Spruce Grove Alberta Canada
    I really dont think microscopic germs are an issue in your motor... it is way to hot for anything to live through that
  20. Aug 31, 2009 at 9:34 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    We were speaking metaphorically.:D
