AFE Pro Dry S air filters in Canada?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eesh, Mar 2, 2009.
  1. Mar 2, 2009 at 8:07 PM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    Anyone know where you can get AFE Pro Dry S air filters in Canada??
  2. Mar 2, 2009 at 8:46 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
  3. Mar 2, 2009 at 8:57 PM
    Eesh
    Canada
    2025 Tacoma Limited
  4. Mar 2, 2009 at 9:11 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Simple green.
  5. Mar 2, 2009 at 9:16 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Our revolutionary new dry synthetic media is easy to clean, and offers three cleaning options:
    [​IMG]Tap Clean: You can tap your Pro Dry S filter and return it to 85% of its original airflow. Simply remove the filter from the intake kit and lightly tap it on a solid surface. Tap and turn the top and bottom of the filter until most of the visible dirt has been released. Reinstall the filter in your vehicle. Do not apply oil to the filter.
    [​IMG]Vacuum clean: You can vacuum your Pro Dry S filter and return it to 96% of its original airflow. Remove the filter from the intake kit and vacuum away the dirt using a shop vacuum or regular house vacuum. Reinstall the filter in your vehicle. Do not apply oil to the filter.
    [​IMG]Wash clean: You can wash your Pro Dry S filter and return it to 100% of its original airflow. Remove the filter from the intake kit. Run the filter under running water from the inside out. Turn the filter to remove all visible and hidden dirt. If your filter is coated with grease or road grime, it may be necessary to use soap and water to get it fully clean. You can completely submerge the filter in a mixture of warm water and mild detergent (use a common household detergent such as dish or liquid laundry soap) if needed. Rinse clean. Allow the filter to dry completely (our synthetic media dries quickly and should dry within a few hours in normal conditions). Reinstall the filter in your vehicle. Do not apply oil to the filter.
  6. Mar 2, 2009 at 9:28 PM
    Eesh
    Canada
    2025 Tacoma Limited
    Is the AFE Pro-GUARD 7 also a reusable filter? Is it better than the AFE Pro Dry S?
  7. Mar 3, 2009 at 11:00 AM
    09 tacoma trd
    ontario, canada
    yes it is a reusable filter. cost about 2 dollars more from napa. i don't know if it is better. i had the same problem as you, which one .so i went with what everybody else was using and it has good reviews so i went with the pro dry s. it does have a little more throttle response.
