AFE stage 2 si install pics
Discussion in 'Performance and Tuning' started by SilverSeven, Oct 5, 2010.
  1. Oct 5, 2010 at 2:21 PM
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    Can anyone please post pics of their afe stage 2 si box installed? I need to know if itd fit with my setup. Also, how able am i to move the placement of the box?
    Thanks in advance!
  2. Oct 5, 2010 at 5:41 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Not sure what you mean about moving your box.
    What is your setup???
  3. Oct 5, 2010 at 5:59 PM
    SilverSeven
    Jordon
    South Jurzee
    this is my setup. I dont think the box will fit in the designed location, so I would have to move some things around.
  4. Oct 5, 2010 at 6:07 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I think you would have to modify the box, but I believe the intake tube wouldn't hit on your engine cage.
    Also for your info I think you have a coilover growing into your engine bay :D
  5. Oct 5, 2010 at 6:09 PM
    roxspin72
    NC
    Oh Yeah!!!
    Wow, that's interesting.
    Hmmm, where is your stock intake getting its air from now? Maybe you can run an inlet tube to the fender, and just run an AFE pro dry filter in the stock location. This way you get cooler air, and the benefits of a dry filter.
  6. Oct 5, 2010 at 6:17 PM
    SilverSeven
    Jordon
    South Jurzee
    thats not possible, it would have to be extremely pinched and restrict flow
  7. Oct 5, 2010 at 6:26 PM
    SilverSeven
    Jordon
    South Jurzee
    yeah I hear that. I will probably end up doing a full custom enclosure. But I'll still need a CAI to build it around.
  8. Oct 5, 2010 at 6:28 PM
    SilverSeven
    Jordon
    South Jurzee
    what about rotating the box so it sits up and down? would it clear the hood?
  9. Oct 5, 2010 at 6:30 PM
    ktmrider
    Junk
    I dont think so unless you cut the box and remade it, even then you would have no access to the filter unless you take the box out.
  10. Oct 5, 2010 at 6:34 PM
    roxspin72
    NC
    Oh Yeah!!!
    I would go this route. After looking at that pic for a while, you will never really be able to run an aftermarket CAI, I.e. TRD/AFE/Volant, without hacking it all up and deleting the effects of a CAI.
    The URD TCAI is routed toward the grille. This will be your best bet. Only reason I did not go this route was because I didn't want to hack into my grille area... But you on the other hand need to fab anyways. Soo, I say go for it. It's Cheaper than AFE, and lots of Taco owners stand by it's performance gains.
    Contact Gadget at URD, you wont regret it:cool:
  11. Oct 5, 2010 at 6:39 PM
    SilverSeven
    Jordon
    South Jurzee
    problem is its in the grill, and will suck up water all day. I need something that goes to the fender. A standard CAI will hook up to my throttle body and run past my strut tower and end up right by the fender, then its just a matter of boxing it in. Ideally the AFE would fit some way some how (on its side?) and then its plug and play. Otherwise I have to fab up a box, which in the end will be cleaner, and more water tight, but more work and more $$.
    fuck it
  12. Oct 5, 2010 at 8:14 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Make a custom snorkel... If you get creative... That would probably fit you best...
  13. Oct 6, 2010 at 8:04 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Might consider running a duct to the fender, then attach a cone filter to the duct inside the fender itself. Not sure how much room is in the fender for a filter though. Just a thought
