Afe twisted steel headers
Discussion in 'Performance and Tuning' started by Yota4me, Oct 28, 2014.
  1. Oct 17, 2016 at 6:00 AM
    #41
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    The cats came from the customers oem headers. Amazon had v-bands on sale last time I stocked up. You will definetly want to use vibrant v-band flanges that self align. I should also note that v-bands aren't necessary. The cats can be welded straight to the header without any issues.
  2. Oct 17, 2016 at 6:02 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Clearly the owner wanted the option to be able to swap out the cats. Which can be a wanted feature, if wanting to swap in "test pipes." As what we did for my GF's headers.
    glorifiedwelder likes this.
  3. Oct 17, 2016 at 6:06 AM
    #43
    glorifiedwelder
    jason
    Santa Clarita, ca
    One more tip if you're going with male/female v-bands is to make sure one header gets a male on the header side flange and one the other header gets the female flange. That way you can't mix up which cat goes on which side. You'll also only need to purchase 1 spare v-band setup to do your test pipes, vs two if you oriented the flanges the same
    12TRDTacoma, Roostfactor and Torspd like this.
  4. Oct 17, 2016 at 6:08 AM
    #44
    glorifiedwelder
    jason
    Santa Clarita, ca
    The owner actually did it for ease of install. I tried to talk him into a set of test pipes while we had everything in the jigs, prior to shipping him back his parts.
  5. Oct 17, 2016 at 8:13 AM
    #45
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Sorry to interject. @IdRatherBNTheSanJuans But I have an extra 2.25" Vibrant v-band for sale if anyone wants it. I bought it from Amazon for my y-pipe install but never used it. It's brand spankin' new.
    https://www.tacomaworld.com/threads...d-flange-assembly-for-2-25-o-d-tubing.440149/
  6. Dec 30, 2022 at 3:22 PM
    #46
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Damn. I have a P0420 code. Replaced the downstream o2 sensor and the code came back. Figured it must be a bad cat. Thought these afe headers looked like a nice option. Found this thread and it looks like they’re garbage, and $1000 more expensive now. Their list price is $1640 or something like that.
  7. Dec 30, 2022 at 4:39 PM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    GESI cats could be an option to have welded in.
    JLink likes this.
  8. Dec 31, 2022 at 5:24 PM
    #48
    JLink
    Josh
    Ocean, NJ
    I found my bank 1 manifold to y pipe flange actually was loose. Hoping that solves it. Ironic that this all started shortly after Toyota replaced my frame…
  9. Jan 1, 2023 at 12:01 PM
    #49
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Very likely a connection. If that was the only problem after a frame swap, I'd say it went quite well. We'll know soon enough if tightening that flange down stops your code issue.
  10. May 26, 2023 at 8:31 AM
    #50
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Bumping this thread. I've got a bunch of stuff apart on my truck (tranny swap) and now looking at just doing headers while I'm in there. I want main cats in place (no cat-less long tubes) so thinking these or the DT. Which would you guys go with? I can weld my OEM cats on with the DT's but my flange stud is buggered so thinking the AFE's would be a nice swap.
    JustDSM likes this.
  11. May 26, 2023 at 9:06 AM
    #51
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I have my reservations on these, especially on boosted 1GR's but I'm thinking I'll pick up a set for the up coming dyno session and parts testing we do (https://www.tacomaworld.com/threads...no-testing-by-ott.759616/page-4#post-28758647) to better assess these on a N/A vehicle.
    DesertRatliff[QUOTED] and Torspd like this.
  12. May 26, 2023 at 5:39 PM
    #52
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I keep reading that in my research about the AFE headers. Thinking DT might be the way to go as I'd love to boost someday. But please keep us posted.
    Also, Justin, I'm really busy and having a hard time carving out time to finish my swap, but I'm going 3rd gen manual RC62f swap in my 2nd gen auto. I'll be reaching out to you to take care of my auto ECU to get it to play with the manual tranny. Thanks!
    Torspd and JustDSM[QUOTED] like this.
  13. May 30, 2023 at 3:57 PM
    #53
    JustDSM
    Justin
    Ogden, UT
  14. May 30, 2023 at 5:11 PM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh wow. That is an upgrade.
  15. May 30, 2023 at 7:37 PM
    #55
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    They tripled in price since last I checked. At least there's a reason other than just inflation.
  16. May 30, 2023 at 7:45 PM
    #56
    JustDSM
    Justin
    Ogden, UT
    Those cats alone are a ~$500 a piece.
    DesertRatliff likes this.
