aFe Y-Pipe (48-46006) or URD Mark 2 Y-Pipe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by livpool14, Aug 1, 2019.
  1. aFe Y-Pipe
    23.5%
  2. URD Mark 2 Y-Pipe
    35.3%
  3. JFR Y-pipe
    41.2%
  1. Aug 11, 2019 at 1:17 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I'm not trying to sell you one as I have more work than I can handle right now but a suggestion would be to read reviews of what people think of the other y-pipes.
    Did performance increase or just noise?
    How did the sound change, better or worse after y-pipe install.
    I never used the other y-pipes but I have been told by others who switched from one of the other y-pipes to mine (the only change on sc truck) made a noticeable performance difference.
    It really depends on your goals.
    DesertRatliff likes this.
  2. Aug 11, 2019 at 1:18 PM
    Roostfactor
    TX panhandle
    What park of OK are you located?
    I'm off the 44 and only 10 mins from the OK border. I'd be happy to show you some stuff.
  3. Aug 15, 2019 at 7:18 AM
    livpool14
    livpool14 [OP] Well-Known Member
    Brandon
    Oklahoma
    2015 MGM Taco OR MT
    aFe CAI Momentum GT Power Package, aFe POWER 76mm Throttle Body, aFe headers, aFe Y-Pipe, TRD Exhaust, VFTune, LCEngineering Dual Comp Clutch - Kevlar, Tilton 6000 Series HRB, URD quickshift, Icon Stage II, Icon Delta Joint UCAs, ECGS bushing, Cooper Discoverer at3 255/75/r17 115T, FN f(x) Pro 17" Matte Black, Ice Gray Katzkin, RCI front skid, Optima Yellow Battery, StopTech Sport Slotted Cryo rotors w/ TRD Brake Pads, Morimoto XB HYBRID LED HEADLIGHTS AMBER DRL, Anzo L Bar Taillights, BAKFlip MX4, 3rd Gen Side Decals, Plasti Dip badges, Cab LEDs, redline hood struts
    @Roostfactor hey sorry man, just seeing this reply.. If you are anywhere close to Shamrock TX, its about a 4 hour drive from Tulsa. I would definitely be interested in meeting up!
    Im starting to lean this way: https://www.urdusa.com/urd-competition-y-pipe-for-4wd-tacoma-v6-2005-2015/ :::: https://www.urdusa.com/urd-spec-u-lt-headers-for-1gr-fe-tacoma-2012-2015-v6/
    Down the road (like, 2-3 years) Ill start looking into one of the endless options of Rotrex Superchargers or a Maggie. So many different Rotrex's and why is the Maggie so expensive with less power provided!?
  4. Aug 15, 2019 at 10:10 AM
    Roostfactor
    TX panhandle
    If you are in Tulsa you are about 3.5 hours from me.
  5. Aug 15, 2019 at 10:39 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    JFR. Full stop.
    I’m surprised to find this is even a question. First of all, which one is equal length? That’s the one to get.
    I started out with a URD and JFR modified the URD to make it equal length. Huge improvement in sound and power as measured on the butt dyno.
    Having experienced first hand.. non-equal length vs equal length back-to-back, I would never recommend an unequal length y-pipe unless there was some sort of packaging issue that prevented equal length from fitting.
    The JFR y-pipe costs more than the other two, but the benefit outweighs the price difference. Additionally, John is a true craftsman and obsesses over every TIG weld. That level of quality shows in the final product.
    Here are some pics of my unequal length URD Y-pipe getting transformed into an equal length. Courtesy of @Roostfactor.
    This is what it looks like out of the box:
    The man, the legend. He re-used much of the original as possible, substituting fresh mandrel bends where needed to get the desired shape:
    Test fitting along the way to make sure everything fits, before fully welding each joint:
    After:
  6. Aug 15, 2019 at 10:45 AM
    Roostfactor
    TX panhandle
    Thanks @loginfailed!
    loginfailed[QUOTED] likes this.
  7. Aug 15, 2019 at 10:48 AM
    su.b.rat
    su.b.rat broken truck
    is there now or in the near future a JFR option for the 2GR-FKS? i am currently on a full custom system with URD Mk2 Y in the mix, but i'm considering another round of improvement.
    Roostfactor likes this.
  8. Aug 15, 2019 at 10:50 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    2025 Underground DCLB Sold 21 Ram TRX Sold 2015 White DCSB Offroad
    Stock for now
    As a owner of a URD one just save up and get the JFR. URD is good until you do headers then the rasp gets unreal. I’ll be getting a JFR soon just gotta get some other things finished before upgrading the exhaust
  9. Aug 15, 2019 at 10:52 AM
    su.b.rat
    not sure if you are replying to me, but if you are i'm in a 3rd gen, 2GR-FKS is the 3.5L. we don't have headers on this motor. only two manifolds.
  10. Aug 15, 2019 at 10:54 AM
    TacoJova
    Central Oregon
    Stock for now
    Was replying to the OP
    su.b.rat[QUOTED] likes this.
  11. Aug 15, 2019 at 10:54 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Unless you get a supercharger this is going to be a waste of time and money and will make your truck sound worse.
    $0.02
    livpool14[OP] likes this.
  12. Aug 15, 2019 at 11:03 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    This is a cool approach, loginfailed and roostfactor. I think I'm going to save these pics and try this when I get some time. My buddy just got a new Alpha TIG I'm anxious to try.
  13. Aug 15, 2019 at 11:20 AM
    Roostfactor
    TX panhandle
    It's quite possible down the road. I have to get caught up on the 2nd gen customers first though.
    loginfailed and su.b.rat[QUOTED] like this.
  14. Aug 15, 2019 at 11:22 AM
    Roostfactor
    TX panhandle
    Sweet! Have fun! It's how I started.
    loginfailed likes this.
  15. Aug 15, 2019 at 11:25 AM
    #35
    Roostfactor
    TX panhandle
    This CAN be a true statement but I respectfully disagree when it comes to my y-pipe.
    There are very specific reasons why the dimensions are what they are.
  16. Aug 15, 2019 at 11:28 AM
    #36
    su.b.rat
    thanks, i'll be watching for you if it can work out.
  17. Aug 15, 2019 at 11:29 AM
    #37
    TacoJova
    Central Oregon
    Stock for now
    I got more power with the URD y pipe and headers NA so I can only imagine yours would be even better :turtleride:
  18. Aug 15, 2019 at 3:10 PM
    #38
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Hopefully your friend has better success with the Alpha TIG than I’ve had with mine.
    First off, mine did one bead and then the high frequency start board went bad. They were really good about it though and they sent me a replacement board for free. All I had to do was take the machine apart swap it out.
    Second, there are a ton of adjustment knobs and you really need to know what they all do and why in order to see good results.
  19. Aug 15, 2019 at 4:35 PM
    #39
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I have TRD SC and run JBA LT headers with the URD y-pipe along with a single Magnaflow cat. converter. After experimenting with various mufflers, I went back to the stock one until it got mangled during a trip. I now have a Walker quiet-flow muffler which rumbles just a tad louder than stock.
    I would recommend only do the URD y-pipe if you're going to do LT headers as well.
  20. Aug 15, 2019 at 4:53 PM
    #40
    Roostfactor
    TX panhandle
    I am into quiet now as well. I tries the 3" stainless Walker Quiet Flow muffler. It was removed after 40 miles. I am now using a muffler from a 2019 Ram 5.7 hemi. All 3" throughout and flows well. It is the cats meow meow!
    TodayWasTHeDaY likes this.
