Affordable (mild) lift options
Discussion in 'Suspension' started by Squid, Jun 18, 2010.
  1. Jun 18, 2010 at 12:01 PM
    Squid
    Squid [OP] Swollen Member
    Dave
    Houston, Texas
    2010 Barcelona Red PreRunner TRD Off Road
    Debadged, Factory Roof Rack, Black Nerf Bars, Black MB Chaos Wheels, 265-75-16 BFG All Terrain T/A KOs, Rear Leaf TSB, Body Colored Grill with center sprayed black
    Looking for a mild lift (2.5") for the front with the rear leveled. I don't plan on any real real offroading, just some trails at the deerlease or down to a fishing hole.
    Money is my biggest obstacle. Would I be ok with a toytec spacer up front and an AAL in the rear, or do I need to go with the 5100s up front? I will be upgrading to 265/75/16s too.
  2. Jun 18, 2010 at 12:10 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    265s will fit stock. 5100s at 2.5 and some trimming will fit 285s
  3. Jun 18, 2010 at 12:10 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Stay away from spacers if possible
  4. Jun 18, 2010 at 12:49 PM
    corman6892
    corman6892 Active Member
    Corey
    Portland, Or
    07 prerunner w/ fiberglass fenders
    cold air intake, 16" black steel wheels, 33" super swampers, 8000k HID's, blacked out headlights, flowmaster, 3" procomp lift kit, procomp light bar, 2 KC off-road lights, 12" sub, 1.5" wheel spacers, Fiberglass fenders, remote start, 6 disc touch screen stereo, and train horn!
    I'd sell you my 3 inch procomp suspension lift for cheap, I got about 2.5 inch lift from it, but it will be a lot rougher ride.
  5. Jun 18, 2010 at 12:55 PM
    Squid
    Dave
    Houston, Texas
    Yeah, but I wll be keeping the stock rims, so I would need to get Spidertrax to run 285s even with the lift, correct?
  6. Jun 18, 2010 at 12:58 PM
    Squid
    Dave
    Houston, Texas
    Ok. Can you elaborate? is it just that the ride would be rougher or is there some other reasoning? Remember, I will not be doing any real offroading. Toytec's FAQ indicates that their spacers are a prefectly acceptable option. Of course, i realize they are trying to sell their product.
  7. Jun 18, 2010 at 1:16 PM
    corman6892
    Corey
    Portland, Or
    It's just a rougher ride because of the tighter suspension, I also had a spacer and that made it rougher too but not as much as the lift kit. It seems like I feel every rock in the road now and I try to avoid all speed bumps, I'm just saying that you are going to miss the stock suspension, so the spacer might be the best option especially for the price.
  8. Jun 18, 2010 at 4:37 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Yep,
    spacers are rough because they preload the coil. For example if you have a 6" long coil and add 3" spacer, your a compressing a 6" coil practically in half
  9. Jun 18, 2010 at 4:59 PM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Someone else correct me if I'm wrong, but installing spacers DOES NOT pre-load the coil...
    It gets placed between the coil-pocket & top of coil assembly.
    If adding a 3" spacer compressed the stock spring 3 inches, no lift would be acheived...
  10. Jun 18, 2010 at 5:21 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'd go with 5100's set at 2.5'' with an AAL in the rear. You can fit 285's on a 4.5 BS rim or less, but with stock wheels you'll need to run Spidertrax spacers for best results. In any case, you will be able to fit 265's just fine also.
  11. Jun 18, 2010 at 5:48 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Very true, but most spacers do pre load by applying more pressure. Some like readylift sit on top of the entire assembly, which dont pre load
  12. Jun 18, 2010 at 6:04 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Throw into the mix the idea that you would want to get new UCAs with anything over 2" or so..
  13. Jun 18, 2010 at 6:06 PM
    Incognito
    VA
    Kind of a hit or miss with this, but it's a good idea to put them in your lift budget. If you get the lift on and it's wandering, then you can go ahead and get some UCA's, but if it's fine without the aftermarkets then that's great/money saved.
  14. Jun 18, 2010 at 9:02 PM
    Squid
    Dave
    Houston, Texas
    I don't think I should need aftermarket uca's for a 2-3 inch lift. i think I'm gonna try 2.5" spacers up front and if the ride is too harsh, i'll replace them with 5100s up front.
  15. Jun 18, 2010 at 9:03 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    im gonna be straight up..
    i think ive seen three different lift threads in the last hour asking pretty much the same thing.
    just try to search...all the answers you need are here somewhere
    not bitching, just saying
  16. Jun 18, 2010 at 9:05 PM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    Just put some hydraulics on it and you can lift it or lower it :D
  17. Jun 19, 2010 at 9:15 AM
    Squid
    Dave
    Houston, Texas
    I see one more, but if you notice, mine was posted before that one.
  18. Jun 19, 2010 at 9:25 AM
    4X4 aggie '13
    4X4 aggie '13 Well-Known Member
    College Station, TX
    09 4x4 TRD OR
    3" toytec spacer lift, n-fab steps
    I have a toytec 3"spacer lift with AAL and nothing else (new ucas, new tires, etc...) and the ride is stiffer but its not extremely bad just speed bumps they are killer. I don't do much off roading just down by the lake and on dirt roads and it works fine for me.
