AFN air filter bad MPG?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rawdoggy, Nov 3, 2020.
  1. Nov 3, 2020 at 10:20 AM
    Rawdoggy
    Rawdoggy [OP] Well-Known Member
    Anyone have an issue with aftermarket air filter and MPG? I’m going to obviously snag an oem and see if it improves. Just seems odd, other than a new radiator and flash awhile back, this is the only thing.
  2. Nov 3, 2020 at 10:29 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Colder air temps?
    Tires dropping a little air pressure due to lower temps?
    Winter blend gas?
    IDK, just three things that come to mind.
    cwdog, Hooper89 and Junkhead like this.
  3. Nov 3, 2020 at 10:58 AM
    Rawdoggy
    It has been like this since June, even in warm temperature. Only 35000 miles on the truck itself.
    Who knows. It’s odd, but also out of warranty now so lol
  4. Nov 3, 2020 at 11:00 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    When you say "flash" are you talking about OV tune? or did you get that tsb reflash for the ecm shifting thing?
    I got the tsb reflash for the shifting issue and saw my mpg drop like a rock.
  5. Nov 3, 2020 at 11:03 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I think he meant flush...
  6. Nov 3, 2020 at 11:10 AM
    Rawdoggy
    TSB reflash. What did you do to fix it? That must be what it was then...
  7. Nov 3, 2020 at 11:10 AM
    5nahalf
    Erik
    Minnesota
    I didnt fix it, I just spend more on gas now :( But I am avg at around 16-17 mpg, I used to be between 19-20
    first 10k miles were 19-20
    second 10k miles are 16-17
  8. Nov 3, 2020 at 11:12 AM
    Rawdoggy
    Lol. I know I went to Toyota. Said you can’t backflash.. apparently.
    hiPSI likes this.
  9. Nov 3, 2020 at 11:16 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You can in a fire...:bananadead:
    G8R_Taco and Junkhead like this.
  10. Nov 3, 2020 at 11:16 AM
    5nahalf
    Erik
    Minnesota
    I think your best bet is to get ovtune, that should undo what toyota did and replace it with a much better tune that will bring back the mpg.
  11. Nov 3, 2020 at 11:18 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    No experience with a Tacoma doing this but I did go through this with my 4Runner. I installed an AEM drop in filter in the factory air box and the MPGs instantly dropped. I never resolved the problem, I ended up going back to a new Toyota filter and the problem disappeared.
    The factory air box with a clean factory filter flows more than the engine can consume, I recommend going back to the Toyota filter.
  12. Nov 3, 2020 at 11:28 AM
    Rawdoggy
    Dope thanks. You don’t have ovtune do you? I think you were the guy I met when we installed that dudes lift at that DIY shop
  13. Nov 3, 2020 at 11:39 AM
    WZ00R2
    TN
    2020 Cement OR
    Yep, that's me. I'm running the latest "final" version of OVtune.
    Are you still in TN?
  14. Nov 3, 2020 at 11:58 AM
    Rawdoggy
    Yep in Clarksville.
    Sent you a PM
