AFR or MAF calibrator
Discussion in '4 Cylinder' started by vtragweed, Nov 7, 2008.
  1. Nov 7, 2008 at 2:42 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i was on URD's site today and looking to purchase one of these to help the power somewhat and i dont know which one to get, i know this sounds crazy but can someone please help me choose what i need
  2. Nov 7, 2008 at 2:51 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    We need to get Gadget in here... I will PM him and ask him about it. ;)
  3. Nov 7, 2008 at 3:33 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    sounds good. i would be interested to know about this as well for my 4 cyl
  4. Nov 7, 2008 at 3:39 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    For 1st Gen, its a MAF Calibrator hands down. Pretty sure it is the same for Gen 2 also
  5. Nov 7, 2008 at 3:43 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    what has to be done with this MAF calibrator im not exactly sure how this thing works
  6. Nov 7, 2008 at 3:46 PM
    dually
    dually Low and slow
    You have to splice wires into your ecu. Then hook a laptop up and start tuning.
  7. Nov 7, 2008 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If supercharged, you need the AFR calibrator. If NA, you need the MAF calibrator.
  8. Nov 7, 2008 at 3:49 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
  9. Nov 7, 2008 at 3:49 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    are these simple to tune
  10. Nov 7, 2008 at 3:51 PM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
  11. Nov 7, 2008 at 3:52 PM
    dually
    dually Low and slow
    That wont work. He has a 2.7 4cyl.
  12. Nov 7, 2008 at 3:55 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    i believe thats the one for 4.0 im trying to find the 2.7, thanks for the try though
  13. Nov 7, 2008 at 4:09 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    is there some kind of computer program you have to put on here to tune it
  14. Nov 7, 2008 at 4:10 PM
    dually
    dually Low and slow
    Yeh, it comes with the calibrator
  15. Nov 7, 2008 at 4:11 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    this should be interesting
  16. Nov 7, 2008 at 4:12 PM
    dually
    dually Low and slow
    do you even have any performance mods?
  17. Nov 7, 2008 at 4:17 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    exhaust, high flow filter w/secondary filter removed thats it
  18. Nov 7, 2008 at 4:18 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    i was wondering if i should get a CAI in place of high flow filter
  19. Nov 7, 2008 at 5:06 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Ok maybe I can help, somewhat...
    I have Intake, Headers, Cat Back, Y-pipe. Puchased the MAF Cali for 229.00, came out to a little over 500.00 with plug and play harness. Did not want to Solder any wires. Yesterday I received my LM 2 scan tool w/wide band sensor. About 350.00 after I had some welding and an O2 bung welded to my header.
    Point is if you are willing to spend the above said amount of cash, and put in some trial and error for tuning, which is layed out pretty easy per Gadgets PDF instructions: http://www.gadgetonline.com/U-Tune.pdf
    then this mod is a good choice. If not keep it simple. As far as a Cold air intake, the stock intake is already designed that way. So unless, you are looking for a more agressive look and sound, I'd invest elsewhere for now.
    By the way, I will post a before and after comparison of my tuning results, and let you all know how easy or not it really is. Tell you what, if I can get it done; there should be no doubt it's easy LOL!
  20. Nov 7, 2008 at 5:42 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    do i really need the scan tool and bung
