After a Tacoma lift hearing a "wu wu wu wu" noise in the front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chancepeeler, Oct 7, 2015.
  1. Oct 7, 2015 at 1:42 PM
    chancepeeler
    chancepeeler [OP] Active Member
    Chance
    2017 Inferno TACOMA TRD OFF-ROAD
    3" Toytec lift, Bilstein 5100's, 33'' Toyo RT
    When driving my Tacoma I am hearing a "wu wu wu wu wu" noise that has rhythm to it. I just added a Toytec 3" lift and 33" Toyo A/T. Had the tires checked and they are not the problem. Also the lift seems to be put on correct. This noise is freaking me out and I took it to another mechanic besides the one who put it on and he told me it was just the truck getting used to the new parts. Its a very light sound but anyone who drives it can hear it if they listen good enough. The mechanic checked the CV joints and said they were not in a bind and had plenty of room. I also added a diff drop kit so they should be fine. First lifted truck I have owned so I might just be hearing things...
  2. Oct 7, 2015 at 1:53 PM
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    It seems like it maybe coming from tires if everything is okay. Check with someone who has those tires but my Duratracs made the same exact noise... It does not mean there is anything wrong it just means your new tires are making a different noise on the pavement.
  3. Oct 7, 2015 at 2:05 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Does the sound go away when you put in 4 wheel drive?
  4. Oct 7, 2015 at 2:17 PM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    ^This^
    Needle bearing :cheers:
    There is a TSB on this, forgot the number though.
  5. Oct 7, 2015 at 2:49 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
  6. Oct 7, 2015 at 3:48 PM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    So if it goes away in 4 wheel drive its the needle bearing, or other way around (i.e., if it doesn't go away in 4 wheel drive its the needle bearing)? I have kind of a "wu wu wu" sound, but its only ever around 35 mph. If I speed up/slow down at all, it goes away. I just attribute it to odd vibrations that happen. I had it pre/post lift.
  7. Oct 7, 2015 at 3:51 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    It could be the tires because of the the lift. Changed the angle of the tire, and now the tread is riding differently on the pavement then it was before the lift.
  8. Oct 7, 2015 at 3:58 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Could be Bubb Rubb
  9. Oct 7, 2015 at 4:01 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I wouldn't worry about it. Lifted trucks push all the tolerances, and there's lots of extra opportunity for minor vibrations. Yes, those will *eventually* cause premature parts failures. If you don't want any risk of anything wearing out early - take the lift off. I just replaced my CV boots at 75k miles as a direct consequence of lift angles.
    Folks have done the ECGS needle bearing bushing replacement. You can pursue that if you want to. But I'd say my truck sometimes does what you're saying - and it has the ARB differential which replaces the driver side bearing completely.
    And clicking your truck into and out of 4-hi at freeway speeds, trying to figure out if it is or isn't the needle bearing, can have it's own unintended consequences.
    Two cents from here:
    Don't worry. Be happy.
    Mcdees84 likes this.
