After Alignment Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mx355, Nov 10, 2012.
  1. Nov 10, 2012 at 7:23 AM
    mx355
    mx355 [OP] Well-Known Member
    Trent
    TX
    2020 Trd Pro
    Kings, Method 316, Nitto Ridge Grappler
    I attached an image of the alignment results. Truck does feel tighter at lower speeds but 65+ it feels to walk or has a slight back and forth steering wheel sway/movement. Is there anything else it could be?
    2010 DCSB Prerunner
    1.75 bilsteins/tsb rear
    265/70-17 now on stock wheels
    Shop removed 17x8 XD wheels, put stock on and aligned and issues occurred after this swap.
    Thanks in advance
  2. Nov 10, 2012 at 7:32 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    they didn't touch the Caster. You should ask them why? It is clearly on the low.
  3. Nov 10, 2012 at 7:38 AM
    mx355
    Trent
    TX
    2020 Trd Pro
    Alright thanks, should try getting it as close to 2 as can right? Due to 1.75 front and stock UCA.
  4. Nov 10, 2012 at 7:40 AM
    Hairy Taco
    North of Hell
    08 TRD
    Yes. If they can push it up to 2 You will notice a difference on the highway. 2.5 would be ideal.
  5. Nov 10, 2012 at 7:45 AM
    mx355
    Trent
    TX
    2020 Trd Pro
    Thanks for quick response. Does everything else look right? Or should I go in asking for 0, 0, 2? Like I asked at first but didn't look at paper until I got home.
  6. Nov 10, 2012 at 7:59 AM
    Hairy Taco
    North of Hell
    08 TRD
    The wander at high speeds is a caster issue. The toe and camber aren't perfect, but you have a lifted truck on stock uca's so there is likely going to be a trade-off somewhere. I would tell them about the wander issue and ask them to push the caster over 2. Hopefully they can do so without increasing camber.
