After alignment truck still pulls.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ispitler, Nov 9, 2022.
  1. Nov 12, 2022 at 6:22 AM
    Ispitler
    Ispitler [OP] Member
    Isaiah
    2013 Tacoma
    Yes, all tires are at the same psi.
  2. Nov 12, 2022 at 6:23 AM
    Ispitler
    Isaiah
    2013 Tacoma
    What’s the way to fix it? Another alignment?
  3. Nov 12, 2022 at 7:47 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Did you try a different shop? Not every shop has a good alignment setup or a competent tech.
  4. Nov 12, 2022 at 2:34 PM
    Ispitler
    Isaiah
    2013 Tacoma
    Not yet but that’s what I’m going try.
  5. Nov 13, 2022 at 4:58 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    I was just thinking, last time I got the truck aligned the steering wheel was off about a degree or two clockwise but the truck still drove fine. After hitting some big rocks on the trail and another alignment, the tech got the steering straight.
    If the truck pulls no matter what it's something else, but if you straighten the wheel and it pulls then you'll have to adjust the tie rods til the steering wheel looks straight. It takes my shop two or three tries and test drives before they're happy with how the steering wheel is sitting.
  6. Nov 13, 2022 at 2:06 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You can check for brake dragging by going for a ride and felling the temps of the wheels. If one side is noticeably hotter than the other, you have probably have a brake issue. Excessive brake dust on one wheel would also be a sign of a brake problem.
  7. Nov 13, 2022 at 11:46 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Pulls to the left when the steering wheel is released or pulls to the left when steering straight?
  8. Nov 14, 2022 at 3:53 PM
    Ispitler
    Isaiah
    2013 Tacoma
    I took my truck to a different shop and got another alignment and they fixed the issue. Thank you everyone for the help I really appreciate it!
