After braking to a stop, Feels like I've been rear ended
Discussion in 'Technical Chat' started by kerrynichols, Jul 2, 2007.
  1. Jul 2, 2007 at 6:48 AM
    kerrynichols
    kerrynichols [OP] New Member
    After I brake hard on my 2002 prerunner DBL cab feels like I've been rear-ended. What is the cause and why can't Toyata admit a problem exists? More importantly, how do I fix the problem that Toyata says is common to all Tacomas?
  2. Jul 2, 2007 at 6:59 AM
    spp
    spp OC, Kalifornia
    OC California
    I had the same with my '99. Cause is axel wrap. Stiffening the rear so the spring won't wind up around the axel will fix it.
  3. Jul 2, 2007 at 8:41 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Either your leaf springs are starting to sag, which means they need to be re-arched or replaced, or you need to grease your axle shaft & u-joint.
  4. Jul 2, 2007 at 5:07 PM
    spp
    spp OC, Kalifornia
    OC California
    My'99 Pre-runner did from the day I drove it new off the lot. Worsened when I put on a shell and after having enough with it I put on some overloads.
    Problem fixed.Rode a little tighter but worth it.
  5. Jul 12, 2007 at 11:07 AM
    Lee's06Taco
    Lee's06Taco Well-Known Member
    Visalia, CA
    TRD Sport 4X4
    My 06 DC does that as well. Not sure of the cause. Let me know when you find out.
  6. Jul 12, 2007 at 1:14 PM
    spp
    spp OC, Kalifornia
    OC California
    Do this test. Load some weight in the bed, enough to make contact with the overload leafs.
    Drive around and see if symptoms disappear. If so, AXLE WRAP.
    Trust me, been there fixed that.
    I discovered this while moving a gun safe for my gunsmith. Put helper springs from Helwig on and problem gone.
  7. Jul 12, 2007 at 9:21 PM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    JCW sells some traction bars from Tacoma's
