After coasting the truck resumes speed with too low of gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KingMoo, Jul 18, 2011.
  1. Jul 18, 2011 at 8:04 AM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    I read a post a long time ago that I can't seem to find now. I'm pretty sure that it was the same problem I'm noticing now.
    Basically, if the truck coasts for a few seconds and then you hit the gas the wrong gear is used to resume speed. Basically it feels like I'm driving a manual and I resume speed using a lower gear than I should...
    Someone mentioned in the other thread that a computer reset fixes this. If so how to I ask the dealer to do this? It's going to be in the dealership this week anyway so it would be nice if they could fix this minor issue
  2. Jul 18, 2011 at 8:06 AM
    Cogge89
    Cogge89 Well-Known Member
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Pioneer AVH-P4100DVD, Kicker ZX400.1 Amp, Kicker CVT 10" Sub. Light Racing UCAs, Front OME Shocks with 885x Coils, Rear OME Shocks with Dakar Leaf Pack, Engine Cover Paint Job, 265/70/17 Duratracs.
    I had the dealer do that shift tsb, mine still does it on occasion. Search around for some tsb info and you should find it.
  3. Jul 18, 2011 at 8:07 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Have you had your gas pedal chop / brake override work done yet ?
    If not , when they do this recall work , the latest software will be loaded into the computer , this includes the tranny tsb update that used to be a stand alone fix .
  4. Jul 18, 2011 at 8:11 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ^ Exactly. :thumbsup:
  5. Jul 18, 2011 at 8:20 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    not sure he needs the chop as he has a 2011. I dont think the 2011 are chop eligible.
  6. Jul 18, 2011 at 8:21 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    forgot to mention i'm in a 2011 TRD sport DC SB...
    I don't think these TSBs apply
  7. Jul 18, 2011 at 8:38 AM
    puckstopper55
    Long Island
    I agree with you ... I haven't noticed this on my 2011 DC LB .. I will check it out on my way home and pay attention .. Is this when using Cruise Control and manually pressing the gas after coasting, or just a normal coast and resume gas ?
  8. Jul 18, 2011 at 8:55 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    coast without depressing the gas then resume gas
    it doesn't happen all the time. probably dependent on what speed and what gear i'm in when i start coasting
  9. Jul 18, 2011 at 8:56 AM
    Ez2typethis
    Ez2typethis Well-Known Member
    Santa Maria, CA
    10 TRD sport 4x4 TRD S/C, TRD Cat back
    My 2010 4x4 TRD sport: Bilstein 5100's in the front set at 1.5" to level, TRD Supercharger, TRD Cat back, TRS retrofit, Satoshi grill, Redlinetuning hood struts, Socked ***SOLD***
    subbed, interested!
  10. Jul 18, 2011 at 9:19 AM
    puckstopper55
    Long Island
    if you try it and notice it, I will try and match. Let me know.
  11. Jul 18, 2011 at 10:14 AM
    OZ-T
    Peter North
    British Columbia
    There is a lag in D as the torque converter unlocks when you accelerate
  12. Jul 18, 2011 at 10:15 AM
    Ez2typethis
    Santa Maria, CA
    A co worker of mine says this happens to him when he is slowing to make a right turn. Says when he starts to accelerate it drops down to a gear too low, like first gear.
  13. Jul 18, 2011 at 10:20 AM
    OZ-T
    Peter North
    British Columbia
    That is corrected with the tranny TSB reflash
  14. Jul 18, 2011 at 10:32 AM
    Ez2typethis
    Santa Maria, CA
  15. Jul 18, 2011 at 11:28 AM
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2011 Tacoma Sport 4X4
    265-70-17 Goodyear Duratracs. Pro Comp 17x8 8089's. Bilstein 5100's front and rear (front set to 1.75). 1/4 inch spacer--driver side. TSB rear leaf springs. WeatherTech floor liners. EGR in-channel vent visors. RDS tool box.
    I've got 2011 DC 4x4, and it does the same thing--when I let off the accelerator to slow down and then resume acceleration, it feels like the truck is in too high of a gear. If I manually down-shift from drive to 4th, it feels like it's where it should be. Is there a fix for that?
  16. Jul 18, 2011 at 11:31 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    My 2006 Tundra did the same thing. I sold it and got a manual Tacoma to cure it.
  17. Jul 18, 2011 at 11:33 AM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    my 11 does not do this after using CC.
    but it'll do that if like at a red light if im still slowing down and i speed up before i stop it'll rev higher than normal. just cause its in lower gear then needed.
  18. Jul 18, 2011 at 11:34 AM
    OZ-T
    Peter North
    British Columbia
  19. Jul 18, 2011 at 11:54 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Nitto Terra Grappler G2, Suspension: Icon coilovers set at 2.5", TC UCA's, 1.5" lift 3 leaf pack with overload left in, 3* shims, carrier bearing drop, Bilstein 5100 B110 rear shocks Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau Cosmetic: window tint, grillcraft black mesh upper/lower grill, eyelids, tinted tails and third brake light, vinyl armrest in doors and center console Lighting: fogs only mod, bed lights in pockets, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights
    I have an '09 TRD sport 4.0. Mine did the lag thing too. Had the tranny TSB reflash done and that fixed it for a while. Now it does it again. :confused:
    Why would a 2011 need this TSB. That should have been fixed with the newer model year.
  20. Jul 18, 2011 at 12:13 PM
    OZ-T
    Peter North
    British Columbia
    I didn't realize the OP had an '11 and my post with the tranny TSB link was for another poster
