After fuel up hestitation
Discussion in '4 Cylinder' started by jmg5wakeboarding, Nov 7, 2010.
  1. Nov 7, 2010 at 3:34 PM
    jmg5wakeboarding
    jmg5wakeboarding [OP] Member
    Louisiana
    01 Prerunner
    3 inch body lift
    I have a 2001 2.7 tacoma and recently after i fill my truck up with gas and start it up it will die or I have to pump the gas pedal. Only happens when i fill it all the way up really. Does this mean my fuel pump is goin out? And at stoplights when im idling it will start hesitating like its going to die. Please help
  2. Nov 7, 2010 at 3:50 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    Are you filling it WAY up, after the auto shut off clicks a few times?
    If so, you may be flooding the evap system, which may pay you the dividend of having to replace the charcoal cannister or some other nuisance repair.
  3. Nov 7, 2010 at 4:24 PM
    radioactivemint
    radioactivemint Well-Known Member
    Oregon
    2011 Reg. Cab 4x4
    Maybe not the case here, but same thing happened to my 94 Accord so it may be worth while to look into. I'd get it filled and sometimes it wouldn't start. Sometimes it'd start and as soon as I started driving the engine would die and I couldn't restart it for a while. Idle at red lights was rough too...felt like it was going to stall. Turns out it was the main relay...replaced that and the problem totally disappeared.
  4. Nov 8, 2010 at 11:22 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Maybe you just got a tank of bad gas? Or has this happened on a few tanks?
  5. Nov 9, 2010 at 6:02 PM
    Kredence
    Kredence Well-Known Member
    Justin
    Arizona
    '00 Runner
    I had the exact same problem on an '02 2.4L. If I filled it to the brim, it would die every now and then right after being started. Never did figure out the problem and additional problems never developed in the truck.
    I figured it was most likely a fuel pump issue but who knows.
    Keeping an eye on this post.
