After Installing OME n LR UCA's.....
Discussion in 'Suspension' started by Fmsvandal, Dec 15, 2009.
  1. Dec 15, 2009 at 11:50 AM
    Fmsvandal
    Fmsvandal [OP] Well-Known Member
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    Toytec Ultimate 3" Lift, Light Racing UCA's, N-Fab Steps, Black Headlight Mod, Satoshi Thin Lip Grille, Painted Hood Scoop, Debadged, Bakflip G2 Cover, Pop/Lock, Alpine HU, Kicker Door Speakers, RE Audio Subs, Arc Audio Amps
    After installing the OME 3" Complete kit along with the LR UCA's on my 09 DC Tacoma i went to get the truck aligned. 2 Diff shops can not get my alignment anywhere near being "green". Any adjustments that can be done to fix camber are maxed out and nothing else can be done.....
    has anybody else had this problem or know what can be done to fix it?
  2. Dec 15, 2009 at 11:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like the Ball joint on the LR's wasnt set correctly
  3. Dec 15, 2009 at 11:57 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    no problems with LR UCA alignment... sorry that sux
  4. Dec 15, 2009 at 11:58 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Do the alignment techs know that the balljoint is adjustable on those control arms? I would reccomend setting the ball joint to maximum Positve caster yourself. Then taking it into the alignment shop and tell them not to worry bout the caster being green, and to make sure your toe and camber are good and then that the caster is close to the same on both sides. That way they only have to use the factory alignment cams.
  5. Dec 15, 2009 at 12:05 PM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    I took it to the best shop here in town.....not sure if they realized the balljoint is adjustable or not. Ill talk to them here in a little when i go and pick it up.
  6. Dec 15, 2009 at 2:07 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    that sucks.no problem on mine.took longer than normal but they got it.
  7. Dec 15, 2009 at 2:26 PM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    and im assuming you have the LR UCAs and not some other brand of UCAs?
  8. Dec 15, 2009 at 4:47 PM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    I found this picture on a diff thread and they talked about it needed to have the SPS facing out like in the picture......if mine is facing in, could that be the cause of us not getting the play we need to get from 2.2 down to 0?
  9. Dec 15, 2009 at 5:08 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Do you still have the instruction sheet that came with the arms?
  10. Dec 15, 2009 at 5:14 PM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    if your talking about the one that shows what positions to put for diff camber positions yes.....
  11. Dec 15, 2009 at 5:35 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Review those positions cuz they can be a bit confusing. Set the it to max positive caster. Then the camber and caster can be adjusted to spec via the lower control arm.
