After lift my traction control kicks on help!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eyesmoke, Feb 11, 2017.
  1. Feb 26, 2017 at 9:04 PM
    #81
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Well, you might need to go back and dig close to 20 years worth of old threads on other toyota forums on the subject. Start by searching Trail Master, Fabtech and Procomp "beer can" drop bracket lifts. That alone will keep you busy reading for a while. Tacoma owners back in the day hated those kits with passion...but that's all that was available.
    Drop brackets are not bad for driving on the street. The issues come when you start wheeling more seriously; cause you will quickly realize that you have less ground clearance, less wheel travel, etc. There are cheaper and more practical ways to fit bigger tires with better off road performance.
    But you are right; any lift will bring issues. It's the nature of the beast with modifications.
    toyota keep adding more electronic crap instead of doing the right thing...which is:
    real front/rear selectable lockers!
    At least that something that engineers got right on the Jeep Rubicons - probably the only thing right in those lol
  2. Feb 26, 2017 at 9:10 PM
    #82
    jmcgrath_22
    jmcgrath_22 Member
    2005 Trd Tacoma
    I'm also not entirely ruling out a recalibration because I almost felt like my truck became more sensitive after they "fixed" it. Hopefully a spec sheet for the 2016+ becomes available like they have for the second gens, then when we know for sure what the perimeters are, we could most likely come up with a solution
  3. Feb 26, 2017 at 9:25 PM
    #83
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    i have mentioned it on 2 different threads, did you or anyone with this problem ever try putting your stock wheels/tires on the vehicle ? I really think, once you go over 33" (the reason most put drop bracket lifts on), i am thinking that the tires are so large, that the parameters that the VSC are calibrated for are thrown off. When going from stock to lifted and 35's, you do not know the cause of the problems. The easiest way to trouble shoot is to use the factory tires. If it stops the problems, you know that cause is the larger tires, if not, then you may have to try a different route. That obvious route is lowering the vehicle, but that defeats the purpose. I have read about VSC calibration which works 1 out of 10 times (i made up those #s), turning of traction control each tire truck is started or using a relay or wiring the switch to turn off on startup.
  4. Feb 26, 2017 at 10:18 PM
    #84
    jmcgrath_22
    jmcgrath_22 Member
    2005 Trd Tacoma
    I understand what you mean and I haven't friend that only because my stock wheels and tires will not fit without running a wheel spacer to clear the drop brackets. I'll dig out my stockers and snag the spacers off my 93 and see what I find out.
    Clay7160 likes this.
  5. Feb 27, 2017 at 1:34 PM
    #85
    dametto.br
    dametto.br Active Member
    Rodrigo
    2016 Hilux 2.8 Turbo Diesel
    Sorry, I did not follow the whole topic. Most likely, the mechanic broke the ABS sensor, known as the speed sensor. When I mounted my suspension it also gave trouble and I had to change the sensor.
    If you have already resolved, disregard my message.
  6. Feb 27, 2017 at 7:01 PM
    #86
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I didn't read your whole post. Most likely a climate control sensor brkmen. One time my climate control broke. That's what I think you should fix. If you already fixed your issues ignore this post.
  7. Feb 27, 2017 at 7:44 PM
    #87
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    That's a lot of added scrub radius...
    The truck thinks it's sliding around corners.
  8. Mar 3, 2017 at 6:39 PM
    #88
    chet043
    chet043 Well-Known Member
    Chet
    16 Tacoma double cab TRD sport long bed
    I did this as one of my first try's to fix. No help
  9. Mar 3, 2017 at 6:47 PM
    #89
    chet043
    Chet
    They hooked up two timed relays to the switch. So when I start my truck it's off. Went on the interstate I want to use my cruise I just reach up and touch the button once
  10. Mar 3, 2017 at 7:24 PM
    #90
    eyesmoke
    eyesmoke [OP] Well-Known Member
    Jay
    va beach virginia
    2017 Quick Sand TRD Sport 4x4 4door
    When you start your car is your dash lights on indicating traction control is off?
  11. Mar 5, 2017 at 8:19 AM
    #91
    browndirtcowboy
    browndirtcowboy Well-Known Member
    Manteca
    Looks sweet. F the haters!!! That Taco is bad ass and those wimpy mofos riding stock and mall crawlin can kiss grits.
  12. Apr 12, 2017 at 11:23 AM
    #92
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    whats the canadian tsb number? my dealer just told me they dont have it
  13. Apr 12, 2017 at 12:23 PM
    #93
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    TSB 4419
    sorgon82[QUOTED] likes this.
  14. Apr 12, 2017 at 12:34 PM
    #94
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    @Coot83 maybe this will help yours? :notsure:
