after lift rubbing
Discussion in 'Suspension' started by BMOC, Feb 21, 2011.
  1. Feb 23, 2011 at 11:24 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Take the wheel off and turn the hub to see if it still makes the noise. It's possible that one of the shields around the rotor got bent when you put the wheel back on. It happened on my friend's tundra after we lifted it.
  2. Feb 23, 2011 at 11:28 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    this happens to me all the time while wheeling, were you in softer sand, dirt when it happened? like a wash?
  3. Feb 23, 2011 at 11:29 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Sent you a pm with availability for meeting you
  4. Feb 23, 2011 at 1:46 PM
    BMOC
    BMOC [OP] Well-Known Member
    Paden
    Phoenix, AZ
    yea, it's like a wash that i've been going through and thats where i was when i first heard it. do you think that could have something to do with it?
    ill try this at school tomorrow :)
  5. Feb 23, 2011 at 1:47 PM
    BMOC
    Paden
    Phoenix, AZ
    yea it's definitely coming from the front
  6. Feb 23, 2011 at 1:55 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    no way youre rubbing the spindle with that much clearance. chances are youre rubbing somewhere else. Its possible youre rubbing the UCA at lock, but it would be obvious as the place where you are rubbing would be cleanly rubbed. Most likely you are rubbing somewhere else.
  7. Feb 25, 2011 at 10:13 PM
    08pretaco
    Oliver
    az
    Ever figure it out? Hit me up, I am available most of the day tomorrow to help you figure it out!
  8. Apr 21, 2011 at 11:40 AM
    BMOC
    Paden
    Phoenix, AZ
    well, i found the rubbing... after cranking up my coilovers on the driver side to even out the taco lean, i noticed a rubbed down spot on the lower control arm which must have come from the tire rub on locked left turns in the dirt...
    not sure if this is normal? i still have stock UCA's and stock wheels and tire's and have never heard of rubbing with a stock setup like that..
    any feedback would be nice :)
  9. Apr 21, 2011 at 12:39 PM
    08pretaco
    Oliver
    az
    its probably because with 3" of lift the wheel and tire assembly gets sucked in so to speak and thats why you are rubbing the arm. most people get 4.5 bs wheels to offset that issue
  10. Apr 21, 2011 at 3:44 PM
    BMOC
    Paden
    Phoenix, AZ
    that makes sense. guess i'll have to get some new wheels and tires soon :p
